Old 11-01-2007, 02:34 AM
Strange electrical short due to alternator overvoltage, HELP!
This is in your territory guys. Refer the thread in Technical and lend a hand.
Old 11-01-2007, 03:18 AM
Svxswede Svxswede is offline
Updated.
Please see http://www.subaru-svx.net/forum/showthread.php?t=41614
regards,
Alex
Ebony mica 92
"You drive a Subaru What?"
Old 11-01-2007, 02:19 PM
Hi Alex
Sorry to see you are in a spot of bother. What you describe is way beyond my experience, and certainly beyond my diagnostic capabilities.
To the very best of my knowledge, NOBODY but nobody has a European workshop manual. If such an items exists it must exist in a vacuum, I've never heard of any member owning one.
But if I'm wrong, chime in with the information and enlighten us all.
I do have the Australian RHD manual, and it is possible the wiring is similar to the Euro model due to the gearboxes and other similarities, but it would not be a surprise if some small differences were there also.
However, when I looked to try and help you, unfortunately I have loaned the electrical volume to another member to try and fix a clocks problem.
If I can get a scan for you I will do so.
Old 11-01-2007, 02:29 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
Given that my Australian RHD manuals also describe the wiring for such features as the seat heaters (that were never offered on AU models!), I think that the wiring for the AU instrument panel would be very close, if not identical to the Euro model.
Watch this space............I shall have a scan of the diagram for you in the next hour or so......!
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 11-01-2007, 03:05 PM
Jason.
Thanks Jason.
I have a scanner here, but not Manual 6, unfortunately.
Old 11-01-2007, 04:24 PM
Good one guys, all hands to the pumps.
Old 11-01-2007, 04:32 PM
JDW-SVX's Avatar
See attached.....
Old 11-01-2007, 04:48 PM
Thanks!
Took a peek before bedtime, and to my surprise, responses are coming in!
Many thanks for the diagram, JDW-SVX, I will continue this elusive bugger of electrical gremlin, tomorrw.
Thanks all,
To be continued,
Alex
Ebony mica 92
Old 11-02-2007, 03:06 PM
A/C control unit??
Basically I have removed most units and relays in order to isolate the short.
Solved:
1. Wiper short fuse 6 (bad relay in unit)
2. ABS fuse 18 (disconnected unit, might take a look inside)
I strongly belive its either a relay or within a control unit. I came to this conclusion as I corrected 3 shorts due to shorted relays, fan left and right head relays in engine comp, and one in the wiper control unit, ABS unit state unknown.
Still have a short when turning to "on", the meter fuse goes bam! (no 15). However its not shorted without ignition turned on. With the dvm hooked in the fuse holder I can just give power for a short second, and also see the amperage through fuse 15.
I hear a relay clicking within the center console, thinking it is the ac control unit. Any tips???
How do I get to it?
I have to check it out, any help would be appreciated.
Alex
Ebony mica 92
