Old 08-19-2007, 05:03 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Nice SVX and pics...
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 08-19-2007, 05:14 PM
Hop Hop is offline
Classic SVX
That thing is beautiful. Made me go out and wax my car. Thanks for the show.
Greg
Old 08-19-2007, 09:36 PM
Nevin's Avatar
Nevin Nevin is offline
Originally Posted by It's Just Eric
Quick grill explanation:
The stock false headlight, refered to as the "waterfall grill" was on all 92-26 svxi
The grill on his car is from a 97 svx. The same grill in chrome was offered on the japaneese svx s4
Smallcar.com makes a grill the is similar to the 97 grill, but the "mesh" isnt surrounded...it's open on the top, much like the waterfall peice
Ah ha! I wondered if it wasn't something like that! Thanks Eric!
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-20-2007, 05:02 AM
The '97 grille is sturdy. I have bought one for mine. Although many love the Waterfall grille, and it is unique and instantly recognisable on the SVX, I prefer the more modern look of the new grille.
Rather than the square plastic matrix in the centre I have a feeling that the grille would be more beefy if it had the metal woven mesh centre like for instance that which is standard on a Jaguar XJR. I'm looking to see if this may be possible to do. I'm trying to figure a neat way to cut out the existing square section plastic centre. However, it occurs that with the woven metal mesh in place in front of that black plastic, the black plastic will not be seen.
Maybe this will be easier than I thought
Old 08-21-2007, 02:55 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Originally Posted by solarsvx
ssvx the pics were taken in downtown baldwin park where my work is
its a old navy base that they converted to ultra hi end living, 900sqf studios go for 300,000$ way over priced
thanks.
the paint looks really good for its age.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-21-2007, 09:12 AM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
Yes it is ... just use gutter guard ... and cut it to fit
This is the waterfall but should work out the same with the 97. I think that's my next project when I give in and buy a 97 grille.
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 08-21-2007, 09:17 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
yea its the ital design one,
im thinking of submiting it in to suby magazine
Do it! Your pearlie looks HOT James!
Chike
2006 Steel Gray WRX TR (sold)
Old 08-21-2007, 06:20 PM
That's a neat job Redsvx.
The mesh you have used here is expanded metal mesh and is particularly easy to bend to shape.
The Jaguar woven metal mesh I mentioned is not so easy to mould to shape, although cutting a flat section of it should be easy enough. I'm going to buy a sheet or two and see what can be done.
Old 08-21-2007, 06:41 PM
Looks great!
Old 08-22-2007, 08:08 AM
redsvx's Avatar
Post some pics when you get it done!
92 SVX LS Pearl
82 Brat 4WD
Bob
Old 08-22-2007, 08:46 AM
I will do Bob.
I've found a place in England that does the mesh.
It looks to me like that style of woven mesh is what SmallCar Performance uses to make their grille. It looks good in pictures, and I was hoping that the "completely surrounded" shape of the '97 grill might look even better with it. The "open at the top" shape of the Smallcar grille looks OK, but I've read a number of posts on here that suggests it is a little flimsy in construction.
Possibly the full surround of the '97 shape may be stronger. I'll post the pics when I make progress
Old 08-22-2007, 09:06 AM
I will do Bob.
It looks to me like that style of woven mesh is what SmallCar Performance uses to make their grille. It looks good in pictures...but I've read a number of posts on here that suggests it is a little flimsy in construction.
Joe,
The small car grille was a real disappointment. It is not real diamond mesh screening, but rather a solid piece of black plastic with a raised embossed plastic design to simulate it.
Look closely at the mesh. In the center of each diamond, a small round hole was drilled out for air flow.
It doe not allow for as much air to flow through the grille as either the 97 or the waterfall grille, whose openings were a lot larger. You would have to dremel out the spaces to the contour of the" mesh", which would make it even flimsier.
Old 08-22-2007, 09:54 AM
Now I see what you mean. I see the little holes. Rubbish all right.
This may seem strange to you, but the UK waterfall grille lets in no air at all. There is a blank piece of plastic at the top, stops all incoming air.
The JDM ones are open at the top, above the waterfall. I can't imagine why this airflow aperture was closed off in the UK ones. The engineers must presume that enough air flows in underneath the bumper to keep it all cool.
There is one difference in the nose of the cars that may account for this. With JDM cars and US cars the front number plate is square. The lower part of it protrudes below the upper bumper, effectively blocking some of the air making its way to the radiators. Possibly having the waterfall grill open compensates for this, or vice versa with the UK rectangular and wide number plate, sufficient air feeds through the lower aperture to keep everything cool, and an open waterfall grille is not needed.
Any thoughts?
Old 08-22-2007, 12:20 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Hey John,
I actually dremeled out the holes in my small car grille. It did not make it flimsy what-so-ever. Also, it looks much better. It was a pain in the @$$, but worth it.
Pictures...don't mind my dirty car...it's been really wet around here.
Close up
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 08-22-2007, 02:31 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
I'm liking that more than the 97' grille, a good compromisse between the 'modern' look and the 'original' look of the waterfall
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
