Old 03-14-2007, 11:21 PM
Ottobon Ottobon is offline
Tan interior=Sex
Question about SVXs AWD
I recently read a article about a australian racing team that ran the R32 skylines back before they where banned, apparently they overrode the 4wd system in favor of a manual torque adjust knob (its late i don't know how else to explain)
anyways the story talked about feeding different ohlms into the G meters and it made me wonder if something like this could be done on a SVX,
what i need to know which way subaru went about setting up the 4wd sensors, did they use wheel speed sensors? or G meters etc?
anyways i currently don't own a SVX but have thought about buying one a few times (had atleast 1 great test drive in a clean 95 LSi) and if i could devise a way of manually adjusting the amount of torque front to rear then i may be all over teh car again, i seriesly would like to own one of these cars someday. anyways if this idea goes kaput then ill probably just keep loving my 1st gen mr2s and alfa romeos
on a bit of a off-topic question: i know the SVX is a wonderful grand tourer, but can it still be aggressive enouph that you sometime feel the need to act like a animal?
Old 03-15-2007, 12:35 AM
Originally Posted by Ottobon
i know the SVX is a wonderful grand tourer, but can it still be aggressive enough that you sometimes feel the need to act like a animal?
Oh yes, it can happen now and again.
Old 03-15-2007, 01:16 AM
nextse7en's Avatar
Graphic Artist
This here topic is 'a gonna get moved.
As far as the question, the way in which our transmissions (USDM models I'm talking about here) split torque will ensure that no more than 50% of power is ever transfered to the back wheels. (front wheels are turned mechanically, rear are driven by viscous coupling (I believe) On paper there is no reason why you cannot override the signal and ensure a 50/50 split at all times. You would need to get a pinout for the TCU, and find which wire to piggyback, and what voltage to send.
Excellent question btw, I'll be interested to hear more information from my fellow members. (and I'm sure I'll be corrected on at least one point.) my only concern would be premature wear.
LAN (aka longassname) would be a good guy to ask about this.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 03-15-2007, 01:29 AM
As far as the question, the way in which our transmissions (USDM models I'm talking about here) split torque will ensure that no more than 50% of power is ever transfered to the back wheels. (front wheels are turned mechanically, rear are driven by a multi plate transfer clutch(I believe) On paper there is no reason why you cannot override the signal and ensure a 50/50 split at all times.
-Patrick
However you would have a car stuch in 4 wheel drive all the time.
This is fine if you do not turn.
But if you turn having the front wheels turning at the exact speed as the rears it would force one end to LOOSE traction!
The front and rear wheels travel different distances in a turn.
At light throttle the SVX averages about 75%FWD and 25% RWD.
Floor it, or get into slippery stuff and it's 50/50.
Old 03-15-2007, 01:33 AM
nextse7en's Avatar
Graphic Artist
Thanks for the correction, svxfiles. I knew there was something off there.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 03-15-2007, 01:39 AM
No problem.
It's 3:39 in the morning,,,,,Whats a life?
Old 03-15-2007, 08:13 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I was wondering about this myself, to go to full time 4wd instead of having it decide on it's own. I would think that all you should have to do is make it think the front tires are slipping all the time, so it will put the 50/50 into effect. I'm just not sure if this could potentially create other problems.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 03-15-2007, 08:35 AM
Mr. Pockets's Avatar
Moderator
Sorry, no. You're close, though.
The front wheels are geared, but torque is transferred through an electronically operated clutch, not a viscous coupling. When more pressure is applied to the clutch, more torque is sent to the rear.
Here's a simple explanation. The car determines how much torque is sent to the rear by comparing the speed sensors in the transmission. One speed sensor watches the front wheels and the other watches the back wheels. WHen the fronts slip, it applies more pressure to send torque to the rear. When the rears slip, it backs off. The change happens before you notice it. Or, rather, it should. If the transfer clutch is worn the fronts can slip for a bit before it happens.
Subaru 5MT transmissions do use viscous couplings, which require no electronics. I don't know about some of the newer, more fancy manuals like the STi, though. Since you can adjust the torque split on that one, I suspect it has an actual center diff.
And, yes, I'm moving this thread to Tech Q&A. Please post in the appropriate forum. If you want to discuss modifying the transmission, well, we have another forum for that.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-15-2007, 08:37 AM
Moderator
I think it would absolutely create other problems. For instance, when solenoid C fails, and the car can't govern pressure to the transfer clutch, the driveline binds up and the whole car shakes in turns.
In my opinion, there's no reason to wire up the solenoid so it's always providing full pressure. The TCU does a greate job on its own, so let it.
2005 Outback
END OF LINE
Old 03-15-2007, 08:45 AM
Manarius's Avatar
Manarius Manarius is offline
Some people have done the "push button solenoid" mod on Legacys with varying effects. Some people have fried solenoid C's requiring tranny removal while others have just gotten a CEL for the TCU not liking the new switch, and some others have had no problems at all (yet). If you really need 50/50 that badly, putting the car in the "1" position with the gear selector will give you a 50/50 split if you have the 4EAT. I personally find no reason to mess with the TCU because it does a fine job of varying torque split.
The SVX has a LSD, which makes for it being very useful in the snow. I don't think I'd see the need for needing a switch to make the car 50/50 split.
-Jason
-Obi Wan Kenobi
Old 03-15-2007, 09:03 AM
JaySVX's Avatar
It wasn't so much a need, or even desire. I was just curious if/how it would be done. In addition i hear so many people using inproper terminology, calling the AWD system 4WD, for instance. 4WD means all wheels have same power at all time, AWD is entirely different, though it seems not many know that.
Old 03-15-2007, 10:14 AM
Moderator
I totally agree.
2005 Outback
END OF LINE
Old 03-15-2007, 11:47 AM
Binding, early tire wear, early clutch pack wear, F/R clutch disc drum breakage, unpredictable handeling, crashing...
Old 03-15-2007, 01:06 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
from what i have read it would be difficult you need to be able to varry the pule telling sol. C to turn on or off.. right?
to keep it on 50/50 all time you would just need to keep power to the sol... or ground...
- John
Old 03-15-2007, 02:18 PM
make sure there is no 12v signal to sol C and you have constant 50/50 AWD... As a victim of this for the past year(i've tried everything to fix it) I wouldn't suggest it
