Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 03-14-2007, 03:36 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Cage installation
Was playing around with the bent steel pipe sitting in the garage beside the racer last night. Looks like it'll fit nicely. Now I just need to get the gas conversion kit for the welder and a gas bottle. Can't find anyone local willing to lease one though. Looks doubtful for an apperance fully done by reading but might get the bar in by then.
Questions I'm coming up with.
1. Should I paint it before installing and then just clean the areas to be welded or wait until its in to paint?
2. Any thoughts on making a seat mounting system that we can switch seats easily?
3. It'll need to have holes cut into the dash yes the dash is back in and looks good at 1/3 of the weight of a stock one. Any ideas on making nice clean cuts large enough to feed it down then an epoxy or something to clean it up afterwards?
Old 03-15-2007, 08:53 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
Paint after you're done welding...are you sure the cage will still be "certified" if you weld it up? I thought you had to have the cage welded by a welder with the right certifications in order for any sanctioning body to accept the cage.
Hole saw!!
You might be able to get by with heavy duty pit pins to hold the seat in - they'd have to be hardened to make sure they're strong enough such that they wouldn't shear off in an accident.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-15-2007, 05:29 PM
dynomatt dynomatt is offline
Paint after welding.
What seat are you using? What quick adjustments do you need, and how long is "quick"?
I can take as many photos of my cage and seat mounts if you want to show you one way to do it...it's probably not the way I'd do it again if I had the choice, but it's the way I've got.
The only other rollcaged SVX I'm aware of is also here in Australia, but it's rubbish.
Old 03-15-2007, 05:58 PM
benebob's Avatar
Right now a plastic summit racing seat (kinda like a dune buggy seat). Looking to put in a Kirkley Aluminum seat in the near future. Maybe next year.
Pics would be great!
Old 03-15-2007, 07:37 PM
benebob's Avatar
Originally Posted by SVXRide
Ben,
Hole saw!!
-Bill
I'm not planning on doing all the welding, just tacking everything in place. I didn't see anything about "certified" welder doing it just that it must meet certain standards for weld penetration and so forth. It took me a good 20 minutes just to test fit the roll bar. Not the easiest thing to get in there to say the least. I'd prefer to do all that stuff rather than pay shop time for it. Remember, the great state of North Carolina certified me as a welder 15 years ago so I'm sure I could always argue that I'm certified. I just drove to NC to do the welding.
Hole saw won't work as the dash needs to come out to weld down there. Its the whole fitting things back together I'm concerned about. Don't want it to look like the Battlestar
Old 03-21-2007, 08:54 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Considering the point of a cage is to save your life, I wouldn't cut corners. If you're not 100% absolutely sure you know what you're doing, take it somewhere. Hell, if you haven't at least "helped" a pro four or five times on cage installs, I'd take it somewhere even if you do know what you're doing. A bad cage will make the car less safe than no cage.
Also, depending on the club/sanctioning body/class you're racing under, the cage will have certain requirements to be legal. Like you said, it's not so much that the welder is "certified", it's that the cage meets the minimum rules... such as pipe material/size, number of mounting points, basic layout, number of bends in a pipe, etc.
Here's some pictures from my WRX cage being installed to SCCA Showroom Stock rules: http://www.seccs.org/forums/showthread.php?t=5589
I sent it to a shop that builds/tunes professional racecars, and *they* sent it to a shop that specifically builds cages because they want to make sure it's safe.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 03-21-2007, 09:38 PM
Ben, I have a tank of 75arg and 25co2 if you need to borrow it. Its a typical mig mixture for mild steel(as long as thats what your cage is made of). Just make sure I get it back in time to make another X-member for reading(someone needed the one I had).
Old 03-22-2007, 11:27 AM
SVXRide's Avatar
by "certified", I meant that the welder understands the specifics regarding how the cage has to be welded and can actually create welds that are compliant.
-Bill
Old 03-22-2007, 12:43 PM
benebob's Avatar
-Bill
What you don't think I can do that? I've done some quite capable work in the past. Just been quite a while. I'll have help. Our helper just got done working on a Spec Micrappy!
Old 04-09-2007, 07:52 PM
benebob's Avatar
Got the feet welded onto the main hoop tonight. Just playing around with the fitment. The SVX floor is gonna be a pain. For a car that prides itself on being flat the floor is anything but.
Old 04-09-2007, 09:24 PM
Pics of what you're doing?
Old 04-09-2007, 09:26 PM
SVXRide's Avatar
Matt,
Do you really want to see Ben's ****ugly welds?
-Bill
Old 04-09-2007, 09:29 PM
If only to compare them to mine
I'm not sure what the floor being flat means for him without pictures...maybe he's doing it differently?
M
Old 04-10-2007, 07:57 AM
benebob's Avatar
Dyno, here's the site that built our cage. The flat floor would be nice for making the sub plates easier to weld. I thought it was close but its a good 1/4 inch off where I want the hoop to go. I think I should be able to bend the 6x6 plate so it goes up the rear seat wall so I can weld the main hoop directly to it but need Dave's fit as well. Wish we were an inch or two closer in height!
http://autoweldchassis.com/rbc.ivnu
Bill you're really trying to replace Wally with Bought not Billt aren't ya! My welds actually look pretty good from last night. Tonight the harness bar goes in. Hoping to have the bar and rear strut tower mounts in by Reading. Wish we had our aluminum racing seat to make fitment easier.
Old 04-10-2007, 10:22 AM
SVXRide's Avatar
Just messing with ya Hey, you're the one the cage is going to protect the first time you put the Racer on its head , so I'd think you'd want to make sure all the welds are right
As far as BNB goes, I'll be doing a lot of work myself on the 'reX to get it into "fighting shape" for the GRC. Paul has provided the "foundation" I'm going to build on. I'm also going to use it as a working jig for some other ideas I've got....
-Bill
