Old 09-22-2006, 05:11 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Question Troubles installing rear speakers
Hey guys ... once again its me..
Im having problems trying to take off the trim above the rear speakers... when i pulled it upward the plastic snap in bolts/screws all snapped out in the middle... but the entire panel is still being held on the left and right side of the car where the seatbelts are... I can not see any screws on the panel.. and I am afraid to pull it to hard... So I am wondering if anyone has done this before and what I should do...
Thanks.
-Sov.
Old 09-22-2006, 05:27 PM
You have to take the side trim panels off (the ones that mount the window switches).
Behind those there will be a screw on each side holding that panel in place.
Old 09-22-2006, 05:29 PM
Sov13t's Avatar
ah okay... any pointers on taking the side panels off? I see 2 plastic screws holding them next to the rear wheel envelope but thats about it for screws... that i can find on them...
nvm... took the bottom of the rear seat out.. found more screws.. thanks!
Old 09-22-2006, 06:02 PM
Sov13t's Avatar
Ah ... Im still stuck took the rear out... found a screw on each panel... took em off... now it seems like something is holding it still... any suggestions..
Old 09-22-2006, 06:22 PM
The front of the panel has plastic clips holding it in. After popping those out you should be able to slide it toward you. There are metal thingies on the back of the panel that also hold it in place but they are of no real concern.
Old 09-22-2006, 08:01 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
If you are talking about the panel under the rear window; you must lift then pull towards you to remove.
