Old 09-22-2006, 02:58 PM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
A ? about making WHEELS...
I have a question and its probably way out there but here it goes. I work in a machine shop and have seen some awesome $hit come off of the machines...Can a set of wheels be made? What CNC machine does it take? What material? and does anyone actually have a program already or do I need to get the engineer to do one?
Please dont laugh at my lack of knowledge! All I am is the purchasing manager and warehouse manager.
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 09-22-2006, 05:56 PM
hmmm a CNC lathe, and 4 HUGE hunks of Aluminum.....
Much cheaper to just buy a set....
Old 09-22-2006, 06:31 PM
What blue lights?
Wink
We have 6 CNC lathes and getting another next week but I was just wondering because I can get the aluminum at a good price I am sure. If I had a program we could run it on a smaller scale and check it on the CMM we just got yesterday then do adjustments from there. Yes ....probably cheaper to buy them! (but so much fun to see something like this roll off the machine!
1995 Green
1992 Black
Old 09-22-2006, 07:05 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Water jet machines are making inroads into the custom rim arena...Chip Foose and others use them for one-off sets.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
NeedForSpeed NeedForSpeed is offline
Great,
Make 18" versions, right and left, of the svx original wheels,
18x8x49mm offset.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 09-22-2006, 07:16 PM
What blue lights?
Originally Posted by NeedForSpeed
Great,
18x8x49mm offset.
That would be super cool wouldnt it? I am sure I cant get a program thats already ready and the engineer having time to entertain my active imagination (and spoiled whims) are slim! if anyone has any ideas I would definately be open to options though!
1995 Green
1992 Black
Old 09-22-2006, 11:01 PM
Speedklix's Avatar
Locker Link Solution
Red face I've seen videos of it...
You start with a wheel blank and the center is cut from a disc as the others just mentioned. It only needs to be a huge cube if you are making it solid from scratch. Which you could use a three axis CNC to do and make a lighter wheel, but with water jet it takes much less time, and less risk of messing up the piece. You just need to come up with your design for the disc to cut in the WJ in a 30-45 degree sweep and rotate that design all around 360 to get it balanced. The disc is ussually set on a big square on what appears to be a motorcycle tire changer and a mig welder slides into a fixed position to run a single bead all the way around as the disc and wheel blank rotate, welding them together. The wheel is then flipped and the same thing happens on the other side without the square in place.
Hope that helps, I have no idea who makes the blanks, but I'm sure you'll find em with the same people who make the tables for welding em.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-23-2006, 08:55 AM
What blue lights?
I would love to see a video on it. I am going to show this post to the engineer and see what he says. I am sure it would be cheaper to just buy the ones I want though.
Thanks for the help, I need lots right now.
1995 Green
1992 Black
