Old 09-19-2006, 09:14 PM
SVXBart SVXBart is offline
transmission acting strange.
so i have picked up my car from subary dealer today.
they have done:
-complet trans flusch + new fluid.
-replaced internal filter(streiner)
i ask thech that was working on it about any metal on magnet and stuck in filter , he said there was nothing unusual for 106 k milage.
i live 10 miles from them.
when i start the car it was in manual mode so i depresed the button
put reverse -ok
put Drive -ok ,so i'm going home(few hills and turns)
first i was suprised how smouthly it shifts(i thought it shifted)but then i realised it was stuck in 2nd gear(4000 rpm whed crouisng 80 mph, and 3000 rpm at 60 mph and couldnt feel any shifting,also when i took my foot of accelerator pedal rpm very fast dopped to 700 rpm)i thought it will kick in when it will get some preasurre.after about 5 miles nothing changed but i was able to put her into power mode .
i decided to go hone and take someone in second car back with me to dealer.
as i pull over at my house i saw little smoke from under the car and engine bay.
after 10 minutes i was pulling of parking when i noticed 2 or 3 power blinks,shifted to D make 20 feet and turn the car off.
when turned it on again- no power light blinking so put in D and go!
1 st, 2nd,3rd,4th it is ok now!made 5 miles test drive ,all good!
someone have any idea what was that all about?
Bart
Old 09-20-2006, 11:50 AM
continue
it is back again.
i sarted car this morning, no power light blinks, but was stuck in 2nd gear again.
drowe her slowly for about 1 mile then stoped and turned engine off.
went to grocery store for about 10 minutes.
started car got 16 power light blinks this time but she started shifting ok.
went back home turned car off and on after 1 minute -no power blinks.
i dont know what this mean, i'm taking her back to dealer.
they broke her they fix her.
Bart
Old 09-20-2006, 12:44 PM
a little more
i repeated self diagnosis tests 3 times to check the codes on transmission (after geting 16 blinks on start up )and couldn't get eanything but continuosly blinking every 1/4 second i stoped counting them after 69 blinks
Bart
Old 09-20-2006, 08:03 PM
hello???
she is back in dealership!
thanks for replays everybody!
Bart
Old 09-20-2006, 08:52 PM
Originally Posted by SVXBart
i repeated self diagnosis tests 3 times to check the codes on transmission (after geting 16 blinks on start up )and couldn't get anything but continously blinking every 1/4 second. I stopped counting them after 69 blinks
After you have done the diagnostic procedure for checking the codes,The "Power" light blinking sequence indicates transmission codes. Long blinks = 10, short blinks = 1. In other words, two long and two short blinks is a code 22. One long and one short is code 11. Blinking once every 1/4 second is normal.
The transmission code procedure can be found here at the SVX Information Warehouse:
http://svx-iw.com/svxiw/article/?article=79
Old 09-21-2006, 09:04 AM
you did the right thing by bringing it back to the dealer
Old 09-21-2006, 05:30 PM
i did the diagnostic 3 times and could not get the code but dealer did and it is duty solen. they are gonna clear it and try driving the car tommorow morning when it will be cold (when engin and transmission is wormed up everything is ok) to see if that helped.
Bart
Old 09-21-2006, 10:26 PM
sounds like the flush may have stirred up some gunka nd stuck yoru duty solenoid...Good luck
Old 09-22-2006, 04:54 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
How are you doing your diagnostic?....I had trouble the first time, but Earthworm confirmed with me that I had to use the shift lock feature and never touch the brake pedal... It worked for me to get my code.
1995 Subaru Svx L / AWD
Old 09-22-2006, 07:46 PM
i know i read yours thread and posts.so i'm sure that i followed the procedure right.
Bart
Old 09-22-2006, 07:58 PM
looks like you right Tom!
they called me this morning and told me that they removed the solenoid yesterday and cleaned it,cleared the trouble cod,and waited till this morning to fire her up when cold to make sure that everything works.
and it seems to be ok.we will se tomorrow morning.
BTW they were very polite and apologized for the trouble that they felt it was they foult.
i'm not suprised since i know them(they also are servicing my wifes MURANO)
and i can tell that Jones Subaru has very good-costumer service.
so my baby is back on the road agein and i bet she cant weit to get her 60k service done in 2 weeks at SVXPERT shop in woodbury
oh boy do i love to drive her
Bart
Old 09-24-2006, 12:07 PM
everything is ok with tranny now!
Bart
Old 10-08-2006, 02:56 PM
It's Just Eric's Avatar
Missing in action
Great to hear
From what I hear, having a transmission power flushed tends to stirr up all kinds of garbage. Ive heard some horror stories of trannies failing just after a service because of this. I wouldnt worry too much about it, but consider doing it youself next time, its no harder than changing the 710
R.I.P Cool Signature.
Old 10-08-2006, 09:35 PM
This is very interesting, in that an often relied upon, multi posting member, in the past suggested that a mechanically defective solenoid would not register a code. This statement I pointed out was wrong. We now have factual evidence accordingly.
