Old 09-15-2006, 11:48 AM
Which one is crank sensor 2??
There are two of them. One is directly over the crank, the other is slightly to the passenger side. Which is which??
Old 09-15-2006, 12:15 PM
Here is a pic of the two...
The one on the left is on the left when looking at the front of the engine, the one on the right is centered over the crank.
Old 09-15-2006, 12:35 PM
Dave, Pull the crank or cam sensor off your Legacy, they look a little different but I believe they will work...and are only $20 new from Subaru...
Old 09-15-2006, 12:37 PM
Dave, there are 2 cam sensors and 1 crank sensor. The cam sensors are on the driver's side cam and one on the crank. The one on the crank is the one you show on the right in the picture. The sensor with the plug terminals pointing straight up and down is the only crank angle sensor. What are the symptoms??
Old 09-15-2006, 12:38 PM
or wait till tomorrow and I can give you one of either
Old 09-15-2006, 12:57 PM
Not sure of the symptoms, I'm trying to help someone out. He's getting a code 29.
I'll probably just send both...
