Old 09-13-2006, 12:55 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Changing valve cover seals
Im doing my valve cover seals because I think that's where my oil leak is oming from. Should I change any other gaskets/seals while im doing the valve covers?
Old 09-13-2006, 01:05 PM
Most of the other seals that cause problems are under the timing belt.
The only other thing to do when you have the valve covers off is to replace the grommets around the bolts holding the valve covers in.
Old 09-13-2006, 01:36 PM
Make sure you have the 3 gaskets and 10 grommets for each side of the engine.
Old 09-13-2006, 06:04 PM
Thank you for the response. I think my leak is coming from the valve covers, since that's where I see oil. What seals are under the timing belt cover?
are they easy to replace? -the ones under the timing belt cover?
Old 09-13-2006, 06:47 PM
Under the Timing Belt Cover is the Timing Belt. Once you get the belt off you can replace the cam seals, the crank seal. You also have access at this time to the waterpump and oil pump.
Old 09-13-2006, 10:54 PM
pavanbabut's Avatar
Can someone give us the list for the cam seals and the crank seal change and also the parts list for oil pump and water pump change.
thanks,
-Pavan
