Old 09-06-2006, 03:50 PM
cdigerlando cdigerlando is offline
Water Pump Replacement Question
Do you think it is possible to change the water pump without removing the timing belt? I thought with a little force I might be able to tension the belt and slip the bolts in. I'm sure it will be a pain though.
Thanks
Chuck D.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 09-06-2006, 04:00 PM
I doubt the timing belt tensioner will let you get away with that...it's just too strong.
Old 09-06-2006, 04:23 PM
Mr. Pockets's Avatar
Moderator
I'm gonna agree with David on this one. That tensioner is really, really strong.
I recommend cutting the belt and stapling it back together.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-06-2006, 04:48 PM
Clamping
I was thinking of clamping the tensioner.
Chuck D.
Old 09-06-2006, 04:50 PM
If you're already at that point then you may as well take the belt off. You're 95% of the way there.
Old 09-06-2006, 06:24 PM
immortal_suby's Avatar
Thread Killah
yeah, I dont get it.
the belt is easy to pop off and back on.
Locker Link
2015 BRZ Limited 6MT
Old 09-07-2006, 07:20 AM
Lazy Change
Well if I can do this by removing just one side of the belt cover and not have to worry about realigning the belt, I would prefer that. I've only done a belt once, and wanted to see if anyone had an easier way to do this. Guess not. Thanks.
Chuck D.
Old 09-07-2006, 08:13 AM
I wouldn't replace the water pump without replacing the timing belt anyways, and the belt HAS to come off, to get the water pump out.
Plus you can't even get to the water pump by just removing the outer belt cover, the center section has to come off, which means both outer ones have to come off....just my thoughts on it.
If you HAVE to reuse the timing belt, just line up the marks before you remove the belt, and put paint marks on the belt to line up with the markes on the pulley, to make it easy to re-align.
Old 09-07-2006, 07:23 PM
belt
Huck. I just changed the belt. Long story, but did not do the pump.
Chuck D.
Old 09-07-2006, 08:04 PM
Then chances are the factory paint marks are still on it...if not, just line it up and put some paint marks on it before you take it off.
Old 09-07-2006, 10:20 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Sorry but I have to chime in. The tensioner is very stong, agree but the bolt, now that is a nother story.
The t-belt did not break either.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
