power light flashing
when i start my car my power light flashes 16 times why??help? stored code, the car shifts fine its weird and it has a new tranny 20k on it with that great genuine subaru remanufactuerd parts sticker-done at a dealer- maybe its a bad solenoid
"wow how much money did it cost for you to do that to your windows, thats some pretty custom $h!t" Last edited by chris92svxlsl; 09-03-2006 at 06:18 PM. |
Go to www.svx-iw.com
Select "SVXipedia" at the top of the page Select "Checking Error Codes" Select "How to check Transmission (TCU) codes |
Or go to the How-To Documents here and look under codes.
Let me guess...code 11? Seems to be by far the most common TCU error code.
ok really weird, i didnt pull up the codes yet, but yesterday, same flashing, then when i drive my speedometer bounces all over the place. I'll be doing 40 and it'll bounce to 30 to 0 back to 40 rapidly all over the place.
"wow how much money did it cost for you to do that to your windows, thats some pretty custom $h!t" |
Speed sensor?
Yeah, that's your speed sensor failing. Soon your speedo will quit altogether.
read post #2 in this thread
If you start your SVX, and your power light flashes 16 times, that is a WARNING that is saying that the TCU is storing a code, but you still have to pull the code from the TCU. Heres what you need to do: 1. Warm up engine by driving at speeds greater than 12mph. 2. Stop vehicle and turn ignition switch OFF. 3. Turn ignition switch ON and make sure POWER indicator lamp comes on. 4. Turn ignition switch OFF. 5. Move selector lever to D and turn manual switch ON. 6. Turn ignition switch ON. 7. Move selector lever to "3" and turn manual switch OFF. 8. Move selector level to "2" and turn manual switch ON. 9. Move selector lever to "1" and turn manual switch OFF. 10. Partially depress accelerator pedal (to turn idle switch off). 11. Check code as displayed on POWER light. Blinking once every 1/4sec is normal. Here are the possible codes: 11 Duty solenoid A 12 Duty solenoid B 13 Shift solenoid 3 14 Shift solenoid 2 15 Shift solenoid 1 21 ATF temp sensor 22 Atmospheric sensor 23 Engine revolution signal 24 Duty solenoid C 31 Throttle sensor 32 Vehicle speed sensor 1 33 Vehicle speed sensor 2 |
