Old 08-31-2006, 11:17 PM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Brake Calibers Front
The guide pin on the bracket for the front caliber can you replace just that-- or does the caliber wear out before the pin--I want to do a brake job but 189.00 for a loaded caliber verse one that is 55.00. I hate to spend that much extra just for the pin. I have a lot of play in the mounting hole in the caliber and the bolt mount insert. I don't mind paying but just for a pin over a hundred bucks i know the bracket does not wear out so i am paying just for the pin---which looks like it is just press in.Other then napa or subaru does anyone else have the calibers.
Thanks
Old 09-01-2006, 05:07 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Yes you can buy the pin from Subaru. Make sure to add anti-seize compound on it when you replace it. This will prevent it from rusting and freezing in place. I believe it costs less than $10.
Old 09-01-2006, 07:13 AM
AJ4U2's Avatar
Pin
Thanks a lot it will save me a bunch of money...Now hope i can get the pin out ok.....They have to ordered it so it gives me time soak it good.
Old 09-04-2006, 09:36 PM
kwren's Avatar
kwren kwren is offline
Unhappy calliper
the bushings in the caliper have to be bad
bite the bullet abd replace the callipers
