Old 03-31-2002, 08:41 PM
justdude
please help...
ok guys,
first time here..i'm pissed..i got this 95' SVX baby with 60K on it...well mentained..
i got it 2 yrs ago when it had 45k on it...
for some reason...i don't much about cars..but once in a while when i'm the first gear going to second the engine "accelerates" by itself without shifting for a few seconds and then it goes back to normal and shifts up... (i don't even know how to explain it)
i don't know why is doing that ..i hate to take to a dealer without knowing what it might be....
can anyone help ...any suggestions , ideas...
thanks guyssss
u r the best!!!
Old 03-31-2002, 09:21 PM
gcookaustin
I don't have an SVX (yet ) but from what I've read on this network is that that is a sure sign that the transmission is about to fail What it is specifically I don't know, but I've heard that it happens usually between gears 2-3. Someone who knows what they're talking about will probably reply to this later.
Old 03-31-2002, 09:26 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: please help...
Originally posted by justdude
ok guys,
thanks guyssss
u r the best!!!
You may not think we're the best when we tell you that your tranny may be on the way out. Sounds like your clutches are slipping from your description. Not a good sign. Obviously, I can't be sure, not being there to "feel" it in person. Also, here is a list of things that could cause slippage from 1-2, according the the trouble shooting chart in the Service manual:
Control Unit
Throttle Sensor (TPS)
Accumulator (2A)
Strainer (in your transmission pan)
Duty Solenoid A
Control Valve
Band Brake
First thing, though, pull your dipstick, and smell your fluid. Does it smell burnt? Is it dark in color (take a white paper towel and lay the dipstick on it. If it's brownish instead of pink or reddish, it's burnt). Perhaps all you'll need is to have your transmission serviced, where they drop the pan and clean the internal filter (strainer). Do you get a "hissing" sound when you take off from a standing start (from your transmission)? If so, it's most probably the strainer.
Try disconnecting the resistor, behind the battery and see if the slippage still occurs. If not, it could either be the resistor, the solenoid (Duty A), or the TPS.
As you can see, there's no "simple" answer. The good news (kinda) is, that when the tranny's just about gone, the slippage starts in the 2-3, not the 1-2.
Best of luck -- and, welcome to the Network.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-01-2002, 02:37 PM
I_Alcyone_I
a while ago mine was slipping between 2nd and 3rd like that. Pulled the resistor behind the baterry and it works perfect now. Hopefully that's your problem.
