Old 07-10-2006, 09:16 AM
Naim's Avatar
Naim Naim is offline
Send a message via Yahoo to Naim
Need help with new front brakes...
I am putting new front rotors and brakes on the SVX...
Installed the new rotor, (took off the caliper braket, then put it back on)
put the brake pads. When I swinging the caliper back down the caliper at the bottom part where the mounting bolt goes through is not clearing the caliper bracket.
The pads are sliding over the rotor just fine and the pistons are compressed all the way.
Any ideas what the problem is???
Thanks
Naim
I bought the car for my wife, but it's my new toy :-)
Old 07-10-2006, 11:19 AM
Check the part where the bottom caliper bolt goes through. It has a rubber boot around it and slides.
Old 07-10-2006, 02:23 PM
Naim's Avatar
Then mine is seized as the stupid thing would not move.
I hope some WD-40 will remedy that.
Old 07-10-2006, 06:34 PM
Naim's Avatar
Damn that thing is seized on there!!!
Can't get the damn thing off...
Old 07-10-2006, 08:49 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You might have to remove the caliper and have a machine shop remove the sleeve for you. When you pick up a new bolt it usually comes with a new sleeve. If you are handy, put the caliper on a vise and bang out the sleeve with a punch and a mallet. Use emery cloth to clean both the inside and outside of the sleeve and the bolt. Also use anti seize compound on both parts before re- installing.
