- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
Their tire machines certainly do. They probably build their own vs. re-badging Corghis like everyone elsse seems to do.
I'll have to agree to disagree when it comes to alignment machines though.
Getting back to the first post, I too have a similar situation.
While cruising on one of our expressways (max 110kph ~68mph!) I started to get a vibration, slowed down it went away. When I accelerated, it came back, when I went faster (who me?!) it went away again. Thinking I had lost a small balance weight and was getting a minor harmonic sinc vibration, I took car for a re-balance. Next weekend, same drive, same speed the vibration came back! It always seemed to occour around 2700 rpm, but cant be sure if lock-up was engaged or not? I did notice that if I pulled back into 3rd (about 3800 rpm @ 110kph), the vibration disappeared. Thinking now at steady cruise the ECU is trying to lean out and maybe I've got a dirty injector that starts to miss? Any other ideas? Arthur.
'80 DL 4x4 Wagon-White (gone) '91 DL 4x4 Wagon-White (gone) '92 SVX LSi Burgundy/Black with wing. (gone) '04 Liberty B Spec 3.0R wagon-Silver '02 Outback 2.5 wagon-White For Sale I Don't Drive Fast, I Just Fly Low!! I've moved to Taree , check out my progress at Picasaweb. That's a 'V' in SVX dammit! |
Highly doubtful. Wouldn't it be easier to feel a lean miss from a failing injector when the load is high, like during acceleration? Cruising at 60mph without a/c, etc. only requires 12-14 hp., roughly. Getting to 60mph requires considerably more.
Road speed steady + rpm change + vibration change = something ahead of the transmission out of balance. Proper testing involves a vibration detection device (such as a Sirometer, about $16 USD) an accurate rpm reading and measuring the diameter of each drive belt pulley. Go here for additional info: http://www.cochran48.com/nvhbuster/about.htm
I had some problems on my 240's balancing, creating a shudder around 55 mph. Basic balancing fixed that, but i can't exactly swap the wheels around to test for that sort of thing, so i need to be careful. 18x8.5's in the front and 18x9.5's in the rear can cause some annoying issues. namely, no rotating...
How wide is the barrel on a stock svx wheel? i'm guessing about 8 inces, but i'm not sure. |
Just in from having my tires re-balanced at a shop with a GSP9700 set-up, First Choice Fast Lube. Clean shop, no wait. Got the usual what-is-this-what's-with-the-windows-say-ya-feel-that-vibration-at-130? business. Making a run to Atlanta later in the week, so we'll see how the old gal does when I can let her stretch her legs a bit.
dcb |
Back from Atlanta
Well, having the wheels re-balanced definitely made a difference for the good at cruising speeds, but something's still occasionally upsetting the car. I paid more attention this time: The shudder happens primarily when the engine's pulling, but not hard. Stomp it for a 35-to-80 mph pass, no problem. Ease on the gas from 35-to-60 and she sh-sh-shakes passing thru 55. Sometimes. Same deal nearing the top of a long, gentle uphill grade at highway speed with the cruise set, only it's less pronounced at higher speed. Click-off the cruise to unburden the drivetrain and she settles-down, then immediately pick-up the throttle and all's good.
The guy who did the balancing said one of my wheels (now left-rear, I believe) was "just a little bit" untrue, and he found and removed a row of stick-on weights inside one of the wheels. Any damage to that wheel must predate my ownership, 'cos I haven't hit anything. Oh, and I think the left-rear wheel bearing's trying to tell me something. Again. I'm more curious than concerned; I mean, I drove 300+ miles yesterday and still have the fillings in my teeth, so I'm not about to go throwing lots of money at the car hoping to luck upon a culprit. But it would be cool to figure out what's causing this. dcb Last edited by dcarrb; 07-14-2006 at 07:56 AM. |
Vibrations that occur only while under power only come from several things: engine misfire, but that is more prevalent under heavy load. Torque convertor shudder at lock-up, but if you were at speed for a while it was probably already engaged. If you accerlerated hard enough for it to disengage, then re-engage you may have felt it, but it only lasts for a second or so. You'll just have to pay attention to whether or not it is in lock-up or not. The more common cause for power-applied vibration is worn/loose u-joints, worn inner cv joints (rare) and driveline angularity issues, which I know at least a number of SVXs have problems with, mine included. Some are worse than others, I have mine almost licked but I only piddle with it once or twice/year.
Driveline angularity issues? As in, something somewhere's not straight, square or true? Reckon I'll just keep poking around. Thanks again for the input. dcb |
