Old 05-30-2006, 06:43 PM
shotgunslade's Avatar
Formula 101
Went to a Formula 101 event last week. Four hour session gets you about 15-20 minutes of seat time. But what a 15 minutes. About 30-40 laps around the below two circuits, about 3/8 of a mile each.
Driving a Formula Ford type open wheeled car. About 135 horsepower in a 900 lb. dry weight vehicle, four speed transmission. Zero to 60 in under 5 seconds. Get up to about 65 mph on these tracks. Just about top out 3rd gear at 5500 rpm.
Here is the car:
Her I am putting the car on. You wear it, instead of getting into it. Walked around with a big grin the entire weekend. Will definitely do it again.
So after this, I'm ready to try Autocross in my SVX.
Old 05-30-2006, 07:49 PM
Speedklix's Avatar
Locker Link Solution
...so where do we sign up?
Looks like you had a lot of fun.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-30-2006, 07:56 PM
A lot of fun
www.formula101.com
The events are held in the parking lot of the big Hershey amusement park in Hershey, PA. They also do them someplace in Ontario, I think.
