Old 04-28-2006, 04:06 PM
shotgunslade's Avatar
5 MT AutoXers
Seeking advice from 5MT owners who autocross. Am now familiar with the general understeer and forgiving nature of the 4EAT car on the track. Even though track turns aren't as tight as AutoX, there should be similarities, especially when you get into the turn too hot. The 4EAT tends to start plowing with maybe a little terminal tail switch. Getting on the gas and turning more tightly causes the car to drift out, without either end getting loose. On the 5MT, how does the 50/50 torque split and the more direct engine connection affect the SVX's handling? Tips in advance of my first 5MT track day would be appreciated. Thanks
Old 04-28-2006, 04:15 PM
mbtoloczko's Avatar
sans SVX
I never was able to fully kick out the rear end of my 5MT except one time when I whacked the brakes mid-corner. I imagine your car will still understeer as it did with the 4eat.
Mychailo
Visit my locker
Old 04-28-2006, 05:03 PM
I noticed the same thing. Sometimes it feels like the rear is going to walk around on you but it never ever does. You have to pull some Tiff N./Jeremy C. maneuvers to get the back end to kick out
GreenMarine has some experience with this though.
Old 04-28-2006, 10:40 PM
The front end always plowed on my ebony. Really I always wished the back end would have more decision making power in the corners. I attended my 1st auto-X in the 6mt the sunday after reading and all I have say is WOW. What a difference. The ability to kick the back end where u want it keeps the front end from plowing. If you are seriously trying to get rid of this kind of manuvering difficulty, there is a center differential available for 5mt boxes that will convert it from the 50/50 split to 35/65 like the 6mt's. They are fairly pricey and can be found at www.Rallispec.com. I am sure there are other sources but this is one I know of for sure.
Edit: Just took a look at the price again and at $1438.00 for the Cusco Tarmac center diff. I don't blame you for reconsidering. Might as well pick up a 6mt for that price
Old 04-29-2006, 07:23 AM
On the track with higher speed turns, kicking the rear end out is not so important. Predictability is what is really important. Don't want any surprises. A balanced drift that gets predictably wider with more throttle is more important. The plowing mainly occurs on the 4EAT if you enter the turn too hot and are turning hard while braking hard. I was wondering what the torque split change might do to that balanced drift.
Old 04-29-2006, 08:50 AM
Like I said. It seemed to be much more controllable. When the front end of my car used to plow the corner or just feel front heavy, the rear bias seemed to balance it out and allow the entire car to just glide wherever I wanted it to. Only real problem I was having was figuring out where the course was, it was pretty diff. course
Old 04-29-2006, 09:41 AM
mbtoloczko's Avatar
sans SVX
Tom, its probably not so much the 35f/65r center diff bias as much as it is the limited slip front diff on your 6MT. Gary Sheenan has a thread on NASIOC where he describes trying several different center and front diffs. He was running the Cusco 35f/65r center diff for a while, and then tried a limited slip front diff. The limited slip front diff improved front end traction so much that he removed the Cusco center diff and went back to the standard 5MT center diff.
Mychailo
Visit my locker
Old 04-29-2006, 09:43 AM
thats a possibility, just seems that since our cars are so underpowered, it is easy to controll the slide rather than a worked STI which would end up sidways in the same situation. I loved it and didn't even care about my time, I was having a blast ripping the hell out of the car.
