Old 03-23-2002, 11:13 PM
double0bondo
power steering leak!
can anyone here tell me if there is an obvious spot to look for a ps leak, i was under the car the day i got it and saw it was leaking ps fluid, is this common??
Old 03-24-2002, 12:39 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: power steering leak!
Start with the hoses. If your car is older, the hoses tend to get dry and crack. Consider (unless you see it dripping from the rack specifically) that it may not be a PS leak at all, but, a transmission cooler hose leak. Those hoses are also prone to failure.
The common problem with the SVX PS system is an o-ring that goes south occasionally. Go to the personal lockers link at the top of the page, then, scroll down to the "HOW TO" locker to find instructions and photos. The symptoms of this problem, however, are shuddering and noise at low speed turns (as in, when you're taking off in the parking lot).
By the way, welcome to the Network. We're happpy you're here.
Randy Johnson
Mike Davis -- at Reading VI
