Turbo Question
I need some input on turbos here... I can get a JDM TD04 WRX turbo(908, ported and polished), TMIC, and piping for 300... the turbo is like brand new and has the 5 psi waste gate from a EA82... so my question is as follows:
Whats the air band like on this turbo, any noticable lag, peak power off it, how does it run at lower psi's? Anyone with a Rex should know, this is the turbo you have, this one is just tweeked to be that much better. Thanks. Chris
98 Impreza Wago-O-Doom & Datsun Roadsters |
what exactly do you plan on doing with a top mount IC?? There is no room in an SVX for one without a serious scoop. Also I think the WRX turbos are still going to be too small. Don't forget this isn't a 2.0. It is more than 50% larger motor with higher compression ratio. It will spool the turbo too fast and run out of the efficiency range in no time flat
Tom |
TMIC=Junk, or trade for a FMIC, just part of the package deal... you think it will spool up too quick huh? I have been talking with other turbo pros and they said it takes longer and more to spool up than a T3/T4 hybrid and they seemed to think it would suite the bill perfect, they said with the power I want to make and where in the power band it should actually be a pretty good match. He said as follows:"the TD04 is a great turbo, and even better when it has been modified like the one you talked about. Personally I would install this turbo and then once you feel comfortable with the process and the car itself with boost, run a GT40 and you will be happy with the huge power it will put down, if your looking for that kind of thing." and I lied to him, I said I had the deal on the turbo used from a JDM car(which it is) for 575 for the turbo and IC... and he said that was a steal, so I think it should do alright... Im not looking for insane power, I am looking to perk it up and to keep some of my reliability, so I dunno, this seemed like a better route than every other turbo shop had recomended.
Hey, 300 bucks for a turbo aint bad no matter how you slice it. If worse comes to worse, you can always sell it
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
my 2 cents, for what its worth:
The TDO4L is many times smaller than a T3/T04E(or B or any other trim your referring too) Its closer in size to a full T3 garret. Either way you look at it. Lets look at TD04L-13g, as many people run on the WRX's You can see how much this is not an option. Ive shown from 3700 to roughly 6000rpm, this is a rough plot at 6.5psi. IMO the gt35R is by far the best choice, rediculously efficent from 3-nearly 20 psi on our motor! Duel ball bearing FTW! end 2cents. phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
I'm not sure who is suggesting the mod path for you... but yeah, a td04 is a tiny compressor housing. It is the stock compressor for 1g dsms.
And the step from a 300hp turbo (td04) to a 600hp+ turbo (GT40) its not quite what I would call a logical progression. For 300$ i would buy it, but i wouldn't count on using it on the SVX.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
Thread Tools | |
Display Modes | |
