Old 04-06-2006, 11:03 AM
Dza's Avatar
Dza Dza is offline
#073 of 301
List what's wrong with your SVX(s)
We haven't done this is a while, so here goes:
- Lifter stuck. Produces the loudest ticking noise known to humankind, increases in speed and volume with rpms
- Tires are horrible and deflating from wear
- CEL on, haven't checked this time but assuming knock sensors and O2 sensors as that's what it was before I most recently reset it
- Brakes pads are at approx 5% (guess, but I'm close)
- I get like 12 mpg. When gas is 115.9/L, that sucks. 2xx miles on $60?
- Driver's side wiper blade broken, passenger side doesn't press flat to window
- Battery is an old POS. Does not start in the cold without car being plugged in
- PW control in driver's door doesn't control front passenger window
- Missing engine cover plastic screw
- Ashtray pocket and ashtray door backing snapped
- Trunk release lever stopped doing anything (?) and lever came off
- Gap in the bottom of the Double DIN slot
- No beauty skirt around my head unit
- Trunk lining peeled away from taillight backing causes taillights to fill up with condensation, and trunk to get wet and smelly
- Loose dog food filling up my spare tire well (don't ask)... made worse by the moisture.
But the tranny still shifts smoothly, and I've fixed the other problems that I've had up to this point. I love my car, and with a little TLC and a LOT of cash it will be back to normal.
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 04-06-2006, 11:09 AM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Torn CV Boot, Rear wheel bearings sound dry. But holding off on these right now since I'll prob be putting in a 5 spd in the coming months. I have all the parts to do the repairs tho.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 04-06-2006, 11:10 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Peeling clearcoat
Driver's side rear wheel bearing (soon to be fixed)
Inner tie rod ends worn (soon to be fixed if I could get the stupid locking plate loose)
Floppy center console
Various burnt out LEDs on dash
Cracked engine cover
Seeping engine seals (all of 'em...more than normal)
Worn belts (soon to be fixed)
Exhaust leaks
Despite all that, still great to driver
Old 04-06-2006, 11:28 AM
- Rust on panels where bodywork was done
- needs new paint
- brake master cylinder needs rebuild, system flush
Old 04-06-2006, 11:52 AM
-inoperable security system
-broken driver's side seat belt clip
-detached trunk liner
-crack in center console behind storage lid
Old 04-06-2006, 11:53 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Left half shaft bad.
mirror defrosters do not work.
Struts starting to get soft.
Paint missing on rear spoiler.
Two different head lights.
Alignment out.
But TRANNY is BRAND NEW AND WORKING!!!!!!!!!!
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 04-06-2006, 12:02 PM
DreamingOfSpeed's Avatar
DreamingOfSpeed DreamingOfSpeed is offline
Send a message via AIM to DreamingOfSpeed Send a message via MSN to DreamingOfSpeed Send a message via Yahoo to DreamingOfSpeed
Ok this may take a while-
-Odd rattle coming from front passenger wheel area at slow speeds
-Tires dont hold air even though they are brand new and have be remounted
-cracked rim
-Large rusty spot of front fender
-messed up rear passenger side skirt
-Missing engine cover
-Tranny sometimes refuses to come out of park
-drivers seat wont move forward
-Annoying buzz from bad cat
-Shifts hard from first to second at slow speeds
-BB gun shots in passenger fender, hood, and door
-Dents and paint scrapes in passenger side from neighbors kids
-Wiper stick is on the fritz
-Two speakers are burnt out
-Rims are all scraped up
-drivers side suspension is missing a spacer
-passenger side suspension is missing the same spacer and needs a new strut mount
-Wing is chipped severely
-black top is getting an odd pattern in its clearcoat
-rear window defrost has 2 broken strips
-drivers seat is ripped and cracked along the bottom from high heals and the use of duct tape to cover holes
But my sun visors arent floppy Most of my problems are cosmetic and will be fixed in due time. Even with all its issues and testiness she still is awesome to drive. After all it is an SVX. I'm waiting to move out before i put alot of work into it cosmetically, my neighbors kids have put scratches or dents in it three different times. NO sense in fixing it when its just gonna get messed up again.
Old 04-06-2006, 12:03 PM
Mike621 Mike621 is online now
My Claret:
-Crack in windsheild all the way at the bottom on the black.
-Possibly bad trans mount
*-Needs front seals/ valve cover gaskets
*-left rear wheel bearing noisy intermittently
*-bad struts
-Many dings/scars from previous owners
-Could use new front tires
-Aftermarket exhaust buzzes too often...
*-warped rotors
*= fixes are in the works.. may be completed before Reading.
the good:
Runs and drives great. NO RUST. Everything else pretty much works as it should. From sunvisors to stereo to seats.
Old 04-06-2006, 12:53 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
The list is too long
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 04-06-2006, 01:09 PM
intellibomb's Avatar
intellibomb intellibomb is offline
everything on mine is pretty good..
good tranny engine etc
BUT
BROKEN SWAY BAR LINK RIGHT FRONT (**** TOW TRUCK DRIVERS)
some leakeys here and there
body damage where i had an *ahem* accident
otherwise the best car ever still
Old 04-06-2006, 01:38 PM
mikecg's Avatar
mikecg mikecg is offline
1) Boost leak
2) 6-Speed gear ratios to close together
3) slipping alt belt.
Dont you wish you had my troubles.
Old 04-06-2006, 01:43 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
1) rip in bumer, dent in rear 1/4
2) need to finish exhaust
3)sick of the stock radio
~Phil
Old 04-06-2006, 01:59 PM
dcarrb dcarrb is offline
1) The fluid line to the rear washer nozzle is either broken or disconnected. Came this way and I've just never fixed it, as I rarely need the rear wiper.
2) Light in rear defroster button inop.
3) Paint (specifically clearcoat) not exactly in showroom condition. Cosmetically I'd say she's in slightly better than average shape for her age.
That's it. (Gently knocking on wood.)
dcb
Old 04-06-2006, 02:03 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
So there's a rear washer nozzle, you say? I filled the back reservoir but it never did anything so I haven't thought about it since. Hahaha. Where is the nozzle? I don't think I have ever seen it.
Also, I forgot to mention my sagging visors and my chipped/loose spoiler.
Dan M.
Old 04-06-2006, 02:10 PM
Nozzle is part of the wiper base. Mine didn't work because the hose was kinked. Works now.
