Old 03-30-2006, 11:13 AM
daddy
Wanna get this SVX
Here's a quote from the ad
for sale...
1992 subaru svx
120k miles
13k miles on rebuilt tranny
Ok subaru enthusiasts, I finally have to let my svx go.
1 of only 12,000 imported to the US
Luxury sportscar thats a dream to drive.
This car does have a few problems, which is why im letting it go.
She's leaking oil, like all SVXs.. no big prob, just change the seals and you're golden!
Alternator needs to be replaced or reworked, a $50 fix if you know what you're doin.
I LOVE THIS CAR!!!
New job forces me to let her go, I'm actually weeping right now thinking about it.
Now, is alternator and seals are cheap fixes just like seller says or he just wanna get rid of it?
Old 03-30-2006, 11:16 AM
The Alternator will be more than the $50 he quoted....but seals aren't to expensive...if you do your own labor
Old 03-30-2006, 11:23 AM
mbtoloczko's Avatar
sans SVX
I wouldn't say that any of the oil seals are easy 1/2 hr jobs. The valve cover gaskets probably take about 4 hrs and a number of other pieces need to be removed to gain access to the valve covers. If the front engine seals are leaking that's another 4+ hr (more like 10+ hr) job that takes some special tools. A leaky PS pump requires either rebuilding the pump or installing a new one that is very expensive. I forgot though, if the PS pump reservior is leaking, that one is actually easy to fix. Only about a 1/2 hr job.
Replacing the alternator is pretty easy.
Mychailo
Visit my locker
Old 03-30-2006, 11:39 AM
mikecg's Avatar
mikecg mikecg is offline
HEY!!!!!!
MY SVX DOES NOT HAVE LEAKY SEALS!!!!
yet...........
Old 03-30-2006, 12:07 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
ehhh... I just keep a bucket under it, and pour it back in every morning.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-30-2006, 12:47 PM
It's Just Eric's Avatar
Missing in action
Hell, with my caddy, I just added oil and power steerign fluid every other day. Figure after a week the car changed its own oil
R.I.P Cool Signature.
Old 03-30-2006, 01:09 PM
Crusader's Avatar
Crusader Crusader is offline
$13000 and counting...
Send a message via AIM to Crusader Send a message via MSN to Crusader Send a message via Yahoo to Crusader
Used to have an Escort station wagon that burned more oil than gas
Old 03-30-2006, 01:30 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by mbtoloczko
I wouldn't say that any of the oil seals are easy 1/2 jobs. The valve cover gaskets probably take about 4 hrs and a number of other pieces need to be removed to gain access to the valve covers. If the front engine seals are leaking that's another 4+ hr (more like 10+ hr) job that takes some special tools. A leaky PS pump requires either rebuilding the pump or installing a new one that is very expensive. I forgot though, if the PS pump reservior is leaking, that one is actually easy to fix. Only about a 1/2 job.
I would agree with those estimates.
If the PS reservoir is leaking it probably just needs a new $1 o-ring, and a it's relatively easy replacement. Same with an alternator (but used ones will probably be $50-60 and rebuilt ones over $100.
Luckily for you daddy, you live in NY just a few hours away from one of the best mechanics on the network - TomsSVX! His rates are reasonable and his work is second to none!
2006 Steel Gray WRX TR (sold)
