Old 03-29-2006, 07:05 PM
intelisevil's Avatar
<<<Alcyone
PWR Radiators - $500 Shipped
I talked to Brandon@pwr-performance.com.
He has ten (nine because I just bought one) SVX radiators available for immediate shipment.
He will sell them for $500 shipped to forum members in the 48 connected states. Shipping may be higher to Alaska, Hawaii and other parts of the world.
He confirmed that they are the updated design.
All of my communication was directly to him via email, then he called me to confirm CC# (they don't take Discover). You could probably call their order phone number and ask for him to make sure you get the correct price. I know another member recently called the order phone number and was quoted $600 - Talk to Brandon!
Yes, $500 is a lot of money, especially for my $1500 SVX. To keep my cars running, I'll pay what I have to.
Dan
Old 03-29-2006, 10:06 PM
Thanks for posting this information. Let us know how it looks when you get it and if it is a drop in like it should be now.
Old 03-30-2006, 12:09 PM
<<<Alcyone
NikFu S. also just purchased one, I'm betting he'll get his installed before I do.
If my band-aid holds up, I'm going to wait until warmer weather or at least a dry day, neither one is scheduled within the next ten days . . . I don't have a covered work area.
Dan
Old 03-30-2006, 08:19 PM
I'm the one that called in and was quoted at $600, but I emailed Brandon a few weeks earlier and he said they were $500.
Old 05-02-2006, 11:10 PM
<<<Alcyone
Success!
I finally had a day off with 'proper' weather to be able to install my radiator. Following NikFu's excellent write up, I found the hardest part was removing the darn blue plastic covers they used to seal up all of the orifices! My RotoZip made quick work of the required fan mods.
My upper mounts lined up much better than NikFu's did, I was able to get all four bolts in with no problems. The supplied 16lb 'Stant' style octagonal radiator cap works just fine with the red lock lever pointing straight towards the overflow nipple. The only thing I still need to deal with is the mismatch from the overflow nipple to the stock overflow tube.
On my test drive, it took a couple of extra miles for the TC to lock up. Considering that the air temp was 50-52 degrees today vs. my recent drives at 35-40 degrees on the same route, I'd have to say the extra transmission cooling is really working! Unfortunately, I don't have a tranny temp gauge to be able to prove anything.
One other thing of note, my water temp gauge has always stayed level once it got up to temp, never budging no matter what type of driving (powering uphill or coasting downhill). After things were tested to be leak-free, I played around some. I 'stomped on it' up a slight hill, 5500-6000 RPM for about 15-20 seconds . . . the water temp gauge dropped! When I slowed back down so the cruise control could re-engage at 60 MPH, the TC didn't immediately lock like it normally did . . . was the tranny fluid too cool?
Right now I'm just running water, next week I'll get proper coolant back into her and see if anything changes.
Dan
Old 05-03-2006, 12:58 AM
Dan
LOlo I didn't include that because I thought it was really easy. I just slit one side and they slipped right off. xD
Old 05-03-2006, 11:57 AM
<<<Alcyone
I thought about doing that but I didn't want to scratch the bright shiny aluminum!
Dan
