Old 03-21-2006, 04:05 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by supertole
Does my car have this filter?
What is the role of this filter?
I found the picture at
http://www.svxworldnetwork.org/html/index.html
How to &faqs/ATF Filters
Thanks!
My JDM 94 does not have this filter.
Pat from Levelten told me that they do not recommend installing an aftermarket filter. (Perhaps because Levelten are in the transmission repair business )
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-21-2006, 06:22 PM
supertole's Avatar
supertole supertole is offline
AWD
So you only have also in your SVX one transmission filter, the one of this picture:
http://www.subaru-svx.net/forum/atta...7&d=1142459258
Do you have changed it?
If aftermarket filter is not recommended, what filter could I buy and where?
Thank you all.
P.D.: the brand of the filter I found and I managed to buy is HASTINGS
http://replacement.autopartswarehous...%20Kit&dp=true
October 1994 SVX
Old 03-22-2006, 01:17 AM
intelisevil's Avatar
<<<Alcyone
How much would you be willing to pay for a Subaru 4EAT Recall ATF Filter Kit, including hoses and mounting hardware?
Keep in mind the Perma-Cool kit without the temperature gauge starts at $38.89.
Would you be willing to pay $15, $20, $25, $30???
How about just $9.53 plus $8.95 shipping from www.subaruparts.com?
The super secret part number is: 31099AA091 Just go to your local Subaru parts department, it might cost more than $9.53 but you won't have to pay for shipping.
I had found the part number for just the filter also but it was about $15 so I didn't keep track of it . . .
Dan
Old 03-22-2006, 03:29 AM
b3lha's Avatar
Phil & Belha
Thank you all.
Originally Posted by me to Levelten
Do you think it is worthwhile to install an aftermarket transmission cooler and filter? If so, is there a particular one you would recommend? Would you install it in series/parallel/instead of the stock cooler?
It has been suggested to me to take the output pipe from the transmission, through a filter, then the aftermarket cooler (air/oil), then the stock cooler (water/oil), then back to the transmission.
Is this a sensible course of action?
Originally Posted by Levelten to me
The cooler must be rated at 24,000 gvw.I don't recommend a filter.The best way to run cooler is from stock cooler to the 24,000 gvw cooler to the rear coolerline on gearbox.
I assume the internal filter in the transmission of the '92 was changed both times the transmission was rebuilt. I haven't changed the internal filter in the '94. I know the fluid is circulating OK so presumably the filter is not clogged up.
Phil.
Old 03-22-2006, 07:02 AM
supertole's Avatar
AWD
Dan
Thanks but subaruparts.com doesn't ship international and to see SVX online catalog you must be a US registered user. I knew the webpage but I think I can't buy parts from them
I will recall Subaru to ask them for the filter. I called last week a Kia dealer and Subaru authorised dealer and the guy said to me that there is no transmission filter for SVX I will try calling the big Subaru dealer of Madrid...
The part number you posted is of the filter and the gasket or only of the filter?
There are two internal transmission filters, wich is better? (see photos)
Regards.
October 1994 SVX
Old 03-23-2006, 04:51 AM
<<<Alcyone
The part number 31099AA091 is for the external filter kit that Subaru installed when they recalled cars with the 4EAT transmission. This link shows the mounted filter: http://www.subaru-svx.net/photos/files/How-To/14367.
After you download the file you'll need to add .jpg onto the end of the filename.
The filter is mounted below the battery. The piece of metal at the bottom of the picture with the oblong hole in it is the front left side tie down point.
I hope this helps.
Sorry, I can't help you with the internal filter.
Dan
Old 03-23-2006, 02:49 PM
supertole's Avatar
AWD
Ok thanks Dan, but my car doesn't have the external filter, it's a 1994 SVX and I think that only 1992-93 SVX have this filter (recalled by Subaru). The one I need is the internal but today my Subaru dealer has said to me that there are 2 different filters and that I have to bring the car to his garage for seeing which filter it is and to be changed by them...
Regards.
October 1994 SVX
Old 03-23-2006, 05:38 PM
Regards.
This thread shows the type of internal filter that is in the transmission, and how to replace it.
http://www.subaru-svx.net/forum/show...mission+screen
Old 03-24-2006, 06:07 AM
supertole's Avatar
AWD
Thanks but I already knew this post!
October 1994 SVX
