Old 03-08-2006, 05:50 AM
michael's Avatar
michael michael is offline
What Potholes ???
Perhaps my statement was misunderstood. First, I was pointing out a solution for a UK spec SVX - Can a UK SVX accept solid rotors in the rear? Second, A solution for US spec SVX - Can US spec SVX accept a vented rotor? Some caliapers have the capacity to handle both both solid or vented rotors. Are the part #'s for the caliapers UK & US the same? Will UK caliapers fit US? About the front fitting the rear, that was a stupid question. I forgot about the pads being a totally different size. Since you mentioned the stopping power issue though, I think the proportioning valve would balance any of that out. I don't think 50-50 is achievable with it.
Wanted: Steering Wheel
Old 03-08-2006, 08:03 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by ItsPeteReally
I'm not so sure
There are two components to the dipped beam solution. The first component is the dual filament bulb. When the dipped beam filament is on, the filament is higher than the true focal point of the reflector; throwing the beam generally downwards.
The second component is the ribbing whithin the headlamp glass itself, this acts as a fresnel lens which also directs and focusses the beam. The British readers of the forum will certainly recall the continental touring kit stickies (a bit like an eye-patch) that were stuck over the ribbed portion of the headlight assembly in an attempt to stop everybody on the other side of the English Channel madly flashing at you. Now the fashion appears to be to stick a secondary ribbed lens over the entire lamp housing.
Whilst it might be possible to get somewhere by twisting the bulb itself, I fear that such a solution may prove to be very sub-optimal.
http://www.subaru-svx.net/forum/showthread.php?t=17062
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-08-2006, 09:57 AM
ItsPeteReally ItsPeteReally is offline
Interesting thread.
But I'm still a doubting Thomas
If one headlight design is suitable for all markets, then why are there at least two different assemblies?
The first law of production engineering centres around reducing the number of variant parts. If any nation on earth could be said to be the leader in production engineering then it would have to be Japan, it seems to me that if one headlight design fits all nations, then there would only be one design.
I've just not got my gullible head on today
Old 03-09-2006, 05:19 AM
Fiat lux
Pete
In reality there are two very different headlight designs.
The clever part, that fits all markets with internal adjustment, is the outer dip lamp.
The JDM and USA market got the cheaper plastic lens headlamp. I'm presuming it was a marketing call, as the SVX would have been a more affordable car in these markets, and there were certain cost savers employed for those mass markets in what was certainly an expensive car to produce.
This JDM style lamp had the benefit of being lighter, and also had a fog light built in on the inner side, which the UK and Eur glass fronted variant did not have [and which the Canadian variant uses as "daytime running lights" a la Volvo].
In the English style one, the inner "lamp" contains only a silvered reflector. In contrast, of course, the English and continental ones has a motor built in that varies the dip depending on load. No Japanese or American car ever got this type.
In another thread, I have speculated that the loss of the inner fog lamp for the Euro glass lamps may have been because the engineers used the power wire for the fog light to operate the dipper motor. Sounds penny pinching, but maybe that's how it was. We may never know.
Interesting thread.
Old 03-09-2006, 05:23 AM
Michael, I don't know if anyone has the answer to these questions.
Even if the part numbers were different, the calipers might still bolt up. Nobody has ever done it over here, the main reason being that solid rear rotors are a retrograde step, and as you know, braking capability on the SVX is marginal for spirited driving.
Can any of you UK guys find the part # of the UK rear caliper, so Michael can chase down this answer?
Old 03-09-2006, 05:58 AM
b3lha's Avatar
Phil & Belha
UK/Euro Part numbers and schematics can be got from the Subaru FAST software that Petr posted here a while back. I'm planning to set up a Win95 box in my garage for precisely this purpose, but it's not ready yet.
Old 03-10-2006, 03:35 AM
blueji's Avatar
blueji blueji is offline
part no's
The part no's for the rear brake calipers appear to be the same according to my Subaru-Fast 2 parts CD:
rear right 26692
rear left 26692a
It lists 5 variants and is the same for all.....
Hope this helps
John.
P.s dont want to go off on a tangent, but, following up on a thread on insurance around Dec 05.....just got my new quote.......
£208.50 fully comp, cheap just got cheaper!!
Old 03-10-2006, 05:31 AM
michael's Avatar
What Potholes ???
Is there a way to check if the pads are the same? I think I'm going to try fitting the euro rotors on the rear if the caliapers are the same. I think the us pads may be thicker to compensate for the thinner rotor. I hope the hats are the same size?
Old 03-10-2006, 07:19 AM
b3lha's Avatar
Phil & Belha
rear right 26692
rear left 26692a
Hope this helps
John.
When you say 5 variants, does that include the USA models? subaruparts.com gives the part number as 26220 for "Disc Brake Assembly Rear". From the diagram, this seems to be the complete caliper. Or am I looking at the wrong part?
Nice deal on that insurance. I'll definitely check that out next time I need a quote.
Old 03-10-2006, 11:44 AM
blueji's Avatar
re-check
My apologies, 4 variants listed not 5.....thats what you get trying to 'play' at work....loss of concentration
Here we go,
listed on screen as:
LH LHD
RH RHD
SO LHD
AO RHD
All these codes (not sure what they relate to but no doubt someone will tell me) come up with the same no.
With regards to part no's from the states, I bought tie rod ends from Bimcad in the states, who trades mostly on Ebay, and the guy in the parts dept at my local Subaru dealership cross ref'd the no's..... both different...same part.
He also quoted me for strut top bearings, again different no's identical part,
sometime's you've just got to go for it.
B.T.W Insurance now purchased at £208.45 from More Than......yeeeeehaaaa
