Old 12-22-2005, 11:22 AM
Cappy Cappy is offline
Formally Capuano
Angry Why can't I keep a PWS hose on my car?
It's absolutely insane. The wife's teally has only 41,000 miles on it, and all the hoses and belts appear to be in great shape...except one. It's a low pressure return hose (or so I've been told) going back to the power steering pump. When it falls off, I get a nice big puddle of fluid under the car, and then when I start it up, the rest of the fluid comes pouring out, so I can't drive it without burning up the pump. This has happened FOUR times in the past six months! The first two times, they blames it on the fact that they were using a "similar" fitted hose, but not the exact fit. The last time it fell off the dealer ordered the part from Japan. It cost me a whole $12.85, but they had to give me a loaner car for a week. This week it happened again. While the car is parked - this time it was just for an hour or so - the hose simply falls off! The last two times it has been on very cold nights (10 degrees F) but I can't see how that's got anything to do with anything.
Has anyone else ever experienced this before?
Cappy
'94 LSi Barcelona Red 158,000 miles
'92 LS-L Dark Teal 47,000 miles
'95 Olds Acheiva 104,000 miles
'85 Audi 4000 135,000 miles
'87 Supra 129,000 miles - 2nd JDM engine
Old 12-22-2005, 11:33 AM
tighten the hose clamp?
better hose clamp?
Old 12-22-2005, 11:43 AM
dcarrb dcarrb is offline
The low-pressure PS return hose is nothing but a length of ATF hose available from any auto parts store, secured wth two universal hose clamps. If installed properly there's no way for it to fall off. Something's up, but I can't imagine what. Have someone else take a look.
dcb
Old 12-22-2005, 12:43 PM
Pearlywhites1992
I just got in from putting another clamp on mine.
I had this problem last week, and am scared to death to crank
the steering wheel too hard! I figure a second clamp can't hurt.
Old 12-22-2005, 02:20 PM
Return hose trouble.
The return hose runs through a cooler pipe that runs around the front of the car in the radiator area. If this pipe is dented or bent, it will restrict the flow of ATF back to the pump, causing it to build up pressure in the return line and blow the hose off.
Old 12-22-2005, 02:46 PM
Pearlywhites1992
That sounds quite plausible. Mine only came off the one time, and I was cranking on the wheel, trying to park.
Old 12-22-2005, 03:07 PM
Yes Tim, my wife was driving mine one week after its 100k service , to have the return hose blow off, smoke every where. Refuses to drive it again.
Old 12-22-2005, 09:43 PM
bcpianoman bcpianoman is offline
That's all it took?
If that's all it took to keep your wife from driving your SVX, I'm going to try it too.
Old 12-22-2005, 11:25 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
(digits here.)
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-23-2005, 08:34 AM
Formally Capuano
Thanks guys,
I talked to the mechanic today and he said the clamps supplied with the hose were pretty chincy, and they are double clamping it now with ones that can be tightened. I'm intrigued by the theory about the return line, though, so I'll probably take a look at it & see if there is a bend in the line somewhere. Maybe I bent something when I put the aluminum radiator in last summer, but I sure don't remember that happening.
Cappy
