Old 12-13-2005, 06:48 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
3 cylinder shifts?
At full throttle, the flat-six revs right to the solid red at 7000 rpm before shifting up, and although first-to-second and second-to-third shifts are smoothed by a shift-energy strategy that cuts fuel to three cylinders momentarily, the next ratio hooks up pretty quickly.
Read from an article on subarusvx.com. Is it true? during WOT shifts it cuts 3 cylinders?
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-13-2005, 07:27 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
I have NEVER heard that before.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-13-2005, 07:37 PM
Boxer6SVX's Avatar
http://www.subarusvx.com/articles/article2.html
read it yourself.. second page.
1995 850Ci
Old 12-13-2005, 07:52 PM
Boxer6SVX's Avatar
From the first article on the same page of subarusvx.com
http://www.subarusvx.com/articles/article1.html
Incidentally the engine brain controlled each cylinder bank independently and could momentarily shut one side down to lessen "shift shock" in hard acceleration.
1995 850Ci
Old 12-13-2005, 08:03 PM
Well, I'll be da*mn. I never knew that!
Everyday... something different, something new. I love this site.
Robert
Old 12-13-2005, 09:12 PM
Boxer6SVX's Avatar
Youre telling that to a guy who has owned an svx for one whole month now lol Im learning all kinds of things lol Ditto, loving this site... the info and advice is so valuable
1995 850Ci
Old 12-13-2005, 09:49 PM
intelisevil's Avatar
<<<Alcyone
Here's a good source for lots more SVX trivia:
http://www.svx-iw.com/svxiw/road_track/
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-13-2005, 10:21 PM
OK, the quote here also explains why replacing my O2 sensors all of a sudden caused my shifting to be so smooth. I never mentioned that here cause I felt like it had to be some sort of coincidence and I would look like an idiot making a connection between the two.
But I swear, I replaced the O2 sensors, and my shifting became velvet smooth during normal driving. You can barely tell it's shifting. Before then, it would "grab" the next gear.
Robert
Old 12-13-2005, 10:32 PM
I read that a while back. I'm pretty sure it was discussed at length, at some point.
Old 12-14-2005, 02:23 PM
Boxer6SVX's Avatar
It only does the 3 cylinder shifts at WOT so dont see where it would affect everyday driving but cool cool, always something new... I think each of our cars have a little gremlin in them...
1995 850Ci
Old 12-14-2005, 02:27 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Correct. Here's the thread talking about the 3 cylinder shifts:
http://www.subaru-svx.net/forum/showthread.php?t=20457
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-14-2005, 05:12 PM
immortal_suby's Avatar
Thread Killah
This is why when you keep just short of WOT you can feel a much greater pull into the next gear vs. just a quick shift at WOT. Feels kinda like a slingshot effect when you get it right. Problem is it is tricky to get your foot at the right point to do it every time.
Locker Link
2015 BRZ Limited 6MT
Old 12-14-2005, 06:25 PM
Boxer6SVX's Avatar
When I put it to the floor it stays at the floor.. its not a 5mt so im not burpin it
1995 850Ci
Old 12-14-2005, 06:56 PM
Don't believe all, you read.
That article was written by an auto journalist, not by Subaru.
He got it wrong, the shift between the gear changes only uses the Torque Control to retard the ign, while the change takes place. The cutting of the fuel to alternate cylinders is only done, on a cold start up, when the idle speed is high. When you pull it into D or R it cuts the fuel to alternate cylinders, to lessen the shock that would happen.
If you read the article, he says that the TCU senses the wheel spin, through the wheel sensors. This has lead to the misconception that the ABS sensors are doing the job. Wrong also.
Old 12-16-2005, 06:34 PM
Boxer6SVX's Avatar
Well I would think a reputable publishing would only use kno-to-be-true things intheir publications...
1995 850Ci
