Old 12-10-2005, 01:28 AM
PhillsSvx
the cam that cost me 4k in work
This is a pic of the cam the the gear wave washer came loose and bent the cams in the head that cost me too much.
Old 12-10-2005, 08:12 AM
Wooooooow , what happened? and why 4000$ for a cam? can't you get a replacement for cheap?
Old 12-10-2005, 09:45 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Phil,
I'm not sure why a problem with the backlash gear would cause mechanical failure(s) unless you were waaaaaay beyond the design limits of the EG33. The gear's design is to take up any "slop" between the intake and exhaust gears (when they "mesh" together). Can you provide a little more detail?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-10-2005, 09:58 AM
looks like you simply bent the snap ring that holds the gear on. I dunno though that pic doesn't show much
Old 12-10-2005, 12:24 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Is that 4k because you had to replace the engine?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-10-2005, 01:07 PM
PhillsSvx
well the back lash gear cam loose at high rpms and all the metal wet through the motor from the snap ring and washer i put a new gear on but and when they were in there head a timed and i would spin them the woyld stick bad and were not free spinning it messed up the head so i had to get a new head wail i had the other 1 out i had the it professinaly redone then put some new bearings in to it since there was alot of metal though out the motor this is what really ruined the motor this all ran through my motor and this is just the larger stuff that was in there most of the metal turned into small shavings
Old 12-10-2005, 01:15 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
but still.... 4 grand???
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-10-2005, 01:35 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
I have a gift for you. It is a period. It is used to end sentences.
Very sorry to hear about your troubles. People may better understand you, and help you, if you write a bit more clearly. Best of luck.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-10-2005, 01:39 PM
PhillsSvx
ok you dont understand it says 4k in work not parts. Parts were not alot but i had so ppl do some stuff professinaly. The cams were 250 each 600 for main bearings new valves new lash adjusters 35$ for 2 35X12=420 380 for the head 250 for the connecting rod bearings 170 for all the rings.
just look at all the parts here these things are not cheep.
http://www.subaruparts.com/diag/?sty...&complete=TRUE
Old 12-10-2005, 02:17 PM
svxpert svxpert is offline
<<ok you dont understand it says 4k in work not parts. Parts were not alot but i had so ppl do some stuff professinaly. The cams were 250 each 600 for main bearings new valves new lash adjusters 35$ for 2 35X12=420 380 for the head 250 for the connecting rod bearings 170 for all the rings.>>
WHY? theres plenty of low milage SVX engines found for under $1000
Its not like you put in performance parts...
Old 12-10-2005, 02:33 PM
n00b on demand's Avatar
Yeah really all you had to do is swap the motor out for another SVX motor.
Old 12-10-2005, 02:44 PM
immortal_suby's Avatar
Thread Killah
Locker Link
2015 BRZ Limited 6MT
Old 12-10-2005, 03:41 PM
That is mighty unfortunate.
At least now you have bunch of new stuff. (:
I'd take new stuff over a used engine.
Old 12-10-2005, 05:28 PM
This cracked me up! It's that christmas spirit of giving!
Robert
Old 12-10-2005, 07:33 PM
PhillsSvx
Well when my brother would restored older cars it was very important that you keep everything original.So i thought i would do that and buy all new parts from subaru the car only had 41k on it when the motor went bad. It had 38k on it when i gradguated and my parents gave it to me since i always wanted it.As long as i kept everything orignal because it will be well worth it in the future.
