Old 11-30-2005, 09:35 AM
empera empera is offline
WTB: Power Steering Pump
WTB: Power Steering Pump.
I have a 92, if that matters.
Old 11-30-2005, 10:34 AM
I have one out of a 92 LSL.
What all do you need? Diagram
Just the pump, Tank? Bracket?
PM me with an offer.
Old 11-30-2005, 11:56 AM
The L and LS use one pump the LSL uses a differnet pump...
Try some Lucus Power steering fluid additive first....
Old 11-30-2005, 02:29 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
I've always wondered about that. So they are not interchangeable?
I thought I had a new spare sitting on my parts car.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 11-30-2005, 06:11 PM
immortal_suby's Avatar
Thread Killah
Before you replace the pump check out the power steering O-ring fix in the how - to lockers.
What are the symptoms that lead you to believe the pump is bad?
Some pumps do go bad, but it is far more common for the O-ring to go bad than the pump itself to be bad and the O-ring is a very cheap and easy fix.
Locker Link
2015 BRZ Limited 6MT
Old 11-30-2005, 06:34 PM
The How-To is located here.
Old 12-11-2005, 08:07 PM
wat could be causin it to work only wen rpms are over 1k....
Old 12-12-2005, 03:59 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
i'm not sure what would be causing your power steering not to kick in until 1k rpms other than the 2 main parts of the system (p/s pump or rack & pinion unit). isns't there a sensor on the lsl models (not sure what that does)?
Old 12-12-2005, 06:42 PM
SlonSVX5mt
Talking I might know~!
Lookunder the car at the rack and pinion assembly there should be metal tubes (or piping whatever you want to call it) going across the assembly. Look at the tubes and see if any are bent or squeshed? if they are thats your problem!
SLON
Old 12-13-2005, 02:17 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
My guess is the belt needs tightened.
Brian
Old 12-13-2005, 06:51 AM
i'll look at it wen the damn snow goes away...
Old 12-17-2005, 01:03 PM
ocdiddy02 ocdiddy02 is offline
i have a working power steering pump if you need for $50
