On my stock Pearlie, 125k, with pure synthetic trans oil (BG products) and 4.44s and only the factory trans (rad) cooler. Outside air temp; 62-61f Engine temp; 198f Trans temp after 6.5 gentle miles 128f, at 8 miles 145f On Di's stock 92 SVX, 155k, with generic Dexron3, and the stock (rad) cooler; Outside air temp; 58-60f Engine temp; 203-207 Trans temp; 154 after 6 miles, and just stayed at 154 for the next 22 miles. Note, the Pearlie was started cold, and Di's was started warm. More later. Tom Note, both the synthetic trans oil, and the 4.44s should help to keep the oil temp down.
Before I purchase a cooler, I have one more question. A mechanic, who also races cars for a living told me; a cooler isn't neccessary as long as you use a full synthetic oil. How true is this?
Boston? Cool - I've got family in Salem.
Still in love with my Subie |
View adding a supplemental ATF cooler as cheap preventive maintenance. It's certainly not going to do your transmission any harm to run a bit cooler.
dcb |
Yea, what he said And yes, Boston is cool.... And witches live in Salem, we don't go there Edit: I almost forgot, I have relatives in Washington...
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." Last edited by Whoru465; 10-13-2005 at 02:41 PM. |
You have two options. You can get a standard cooler that fits (about $75) and install it between the radiator and the air conditioning condenser. There is a photo of such an installation at this link: http://www.drwtransmission.com/image...oler_local.jpg Or, you can pay $130 to get one that has a built-in electric fan and install it behind the driver's side fender wall. I attached a photo of such an installation. You can buy that cooler here: http://www.alamomotorsports.com/pmc/Cat_page13-1.html The model you want is either 12511 or 12515. IMPORTANT: Be sure to bypass the radiator's cooler when you install it!!! Do not make the mistake of installing it in series with it, as is the typical configuration for other cars! Good luck! ~ Rad |
If you're running a '92 with the original radiator you should install a filter upstream (if there's not one there already) to prevent possible clogging of the screen inside that model year's radiator cooler. dcb |
And what happens if it doesn't, as often as it used to? Mine has been bypassed for about 5 years now and the tranny is still running the same as before, if not better. I can't say the same for the gas mileage, but I feel much more secure driving around a tranny that doesn't start slipping when it gets hot out. It may not be a good option for someone who lives up north, but here in KC and further south, I don't see it as a problem.
My tranny temps hovers at 160ish on the highway on warm summer days and doesn't lock up until the outside temps get well into the 90's. In heavy stop and go traffic, it can get up to 190 or so, but cools down quickly once the car gets going again. In the winter, it struggles to break 110 degrees when it's below freezing outside, but still drives just fine. I was expecting to replace the tranny 5 years ago, so personally, I feel that the lower temps will help protect the tranny more than having the TC lock more often. KuoH Quote:
#28
But I agree with mbtoloczko, "......in terms of driving experience, I'd much rather have the tranny operating at normal temperature ranges." So I'm going to keep working on the problem. What would be nice would be a 165 deg thermostatic switch which would switch in a by-pass around the stock cooler when the oil reached that temperature. You would think that would hold it at the ideal operating temperature. - Jim
- Jim '02 Outback - Wife's car '96 Legacy Wagon - Son's car '95 Legacy Sedan - #5 Daughter's car '93 Impreza Sedan - #4 Daughter's car '92 Claret LS-L - My car ____________ TOTAL = 595,000 Subi miles |
#29
I guess a question that bears asking is, are you really prolonging the life of your transmission by running a setup which prevents the ATF from reaching normal operating temperature and wastes fuel as a result?
If your answer is yes, then more power to you. dcb |
#30
