Old 09-29-2005, 03:39 PM
djsiva's Avatar
djsiva djsiva is offline
Send a message via AIM to djsiva
How can I tell if my rear diff is LSD?
I had some transmission guy misdiagnose a rear end problem several months ago so I replaced the rear diff in my 94 LSi. I think I may have ended up with a non LSD rear end but I'm not sure how to tell. Any help would be appreciated. Thanks.
Nate
Old 09-29-2005, 03:43 PM
There should be a tag on the rear diff indicating the gear ratio as well as if it's LSD.
Old 09-29-2005, 04:43 PM
Lsd.
I thought that all 3.54 diffs were Limited slip.
Anyway, jack one back wheel off the ground, try turning it, if it is very hard to turn, it's LSD. Easy to turn, it's an open diff.
Old 09-29-2005, 05:36 PM
Manarius's Avatar
Manarius Manarius is offline
Do that and you'll roll the car off the jack.
Better idea: Get two people and get one to hold one wheel and the other to spin the other. After a little bit of turning, the person holding the wheel should notice that it will want to turn as the LSD will be in "locked position."
-Jason
-Obi Wan Kenobi
Old 09-29-2005, 06:05 PM
The car can't roll off the jack, as the parking pawl will prevent the front wheels from moving.
Old 09-30-2005, 11:26 AM
svx_commuter's Avatar
Does the trans have to be in nuetral for this wheel spinning test by hand?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
