Old 09-29-2005, 10:14 AM
1992SVX 1992SVX is offline
weird noise from center of car
the noise is coming from the center of the car. it sounds like a band saw going. it gets louder as u drive faster. no difference if u put in neutral while driveing. does not make that sound while in idle
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 09-29-2005, 12:39 PM
Something rubbing on the driveshaft?
Old 09-29-2005, 02:14 PM
wawazat??'s Avatar
Yeah, I'm still around
My bet would be e-brake cables or one of the heat shields on the drive shaft.
Todd
Down to none
Old 09-29-2005, 02:21 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
svx.net novice says wheel bearings. I've driven my svx for one month now. I replaced the RR wheel bearing. Now I have to replace LR wheel bearing. Both sound as if they are coming from the middle of the car. Sounds exactly like a band saw, noise is speed sensitive, and present regarless of Neutral or Drive! Maybe you've already replaced them but I just thought I'd throw in the obvious.
Old 09-29-2005, 09:24 PM
it is coming from the front of the shifter in the car while driveing. when u put your hand down on floor infront the shifter u can feel a vibration .
Stage1 Shift Kit
4.44 gears
Old 09-30-2005, 04:46 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
That sounds like a heat shields are loose to me. I'd check the welds on them.
Or maybe try feeding a piece of wood underneath....If it comes out in two pieces, then it's definately a band saw...lol
1995 Subaru Svx L / AWD
Old 09-30-2005, 07:34 PM
i found out what it was. it was the heat shield rubbing againest the driveshaft.
i fixed it by giving alittle of prybar persausion.
thanks for all the help
Stage1 Shift Kit
4.44 gears
