Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 12-16-2004, 10:45 AM
gsodonis's Avatar
gsodonis gsodonis is offline
SVX Guages - new look
Here are a couple of pics of a work in process:
I'm playing around with a spare set of Gauges until I get the look I want. Then I'll duplicate the good parts on my stock set.
Ultimately, I'm going to install white reverse glow overlays, but will keep the silver rings. I'm also making white overlays for the two oft ignored ones: the upper left and right lights that depict the side view (FWD, ASR, & AT OIL TEMP lights) and top view (door ajar and seat belt indicators) of the SVX. Since I have a 5-speed, I'm also tired of looking at the transmission position indicator lights, so those will be conered up as well. I'll take picture along the way and probably make this a HOW-TO.
Old 12-16-2004, 10:48 AM
gsodonis's Avatar
Here are the upper left and right white overlays
Here are the v.1 overlays. I'll probably end up making them with blue lines (vs. black) to match the blus of the Reverse Glow EL overlays.
Old 12-16-2004, 10:52 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Thumbs up
I really like the trim rings!!!
The White reverse indiglo aren't my cup of tea, but I'm sure yours will look great!
How did you do those trim rings?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
The silver rings add a nice touch without going overboard.....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-16-2004, 11:05 AM
gsodonis's Avatar
Silver Trim Rings
Believe it or not, the rings are model paint. I'm using a $3.00 Testors silver paint marker.
I've looked for different pre-made bezels, but they're either the wrong size (ID & OD) or too darn thick. Since I have a spare dash, I started playing around with different paints and brushes and then found the paint marker. The size of the marker (both tip and barrel) gives me better control than a brush. You have to be patient and have a very still hand so this is not a mod to try after a couple of Starbucks or tequila shots.
I've tied to imagine every possibility of masking the dash, but the compound curves and tight spaces preclude me from such fanciful thoughts. The openings in the dash for the guages do have a nice radius that actuall helps the paint line stay pretty straight with no masking. Also, I figure if I slip up, I can always use an exacto knife blade to clean up (scrape off) any paint that strays from the proper ring appearance. I'll post the finished product and some of the steps along the way when I'm finished.
Old 12-17-2004, 02:18 AM
Re: Silver Trim Rings
mmm, your lines are not perfect circles, this is what you should make:
1- draw on a piece of vynil slightly bigger diameters than the gauges (more by around 2 millimeter).
2- cut them correctly and stick them right on the gauges contour
3- the Vynil circle will look slightly bigger than the gauge circles on the dash, so there is black plastic finish in between them
4- get your marker and paint the plastic with silver and leave it over night to dry up
5- gently remove the vynil off the gauges and you will have a nice straight circles = professional job
I hope I explained well...
Old 12-17-2004, 04:38 AM
gsodonis's Avatar
Re: Re: Silver Trim Rings
SilverSpear,
You are correct that the lines aren't perfect circles. Remember that this is my experimental dash; I'm not finished with it just yet. I tried cutting tape in a circle, but that proved to be just as hard as painting it perfectly (drawing them is easy; cutting them perfectly is the problem).
Howvere, your reply has given me another thought. I will call one of the companys that makes signs today to ask them to cut me the correct sized circles in adhesive vynil. They can program any cut shape with their software which should allow me to get the correct sized rings to better mask the gauges. I may even have them cut thin rings in silver to see how that looks to make the rings just a bit larger (like the 2004 Sti Guage faces)
I'll post my next test as soon as I'm finished.
Sti Guage Faces
Old 12-17-2004, 05:04 AM
Re: Re: Re: Silver Trim Rings
SilverSpear,
Sti Guage Faces
man you don't need that!! just bring a lousy compass, draw the circles on a piece of something like glue paper (same as the sticking part of the post-its) and do the thing with the marker... the cheapest and reliable way... (no $$$ paid !!!)
Old 12-17-2004, 07:26 AM
GreenMarine's Avatar
From POST-***** to LURKER
Re: SVX Guages - new look
I really REALLY like the silver trim around the gauges... Great job!!
Old 12-17-2004, 08:05 AM
n00b on demand's Avatar
Yeah those rings look sweet!
Old 12-17-2004, 08:21 AM
drivemusicnow's Avatar
Poor College Racer
Re: Re: Re: Re: Silver Trim Rings
like he said.. the compass/drawing is easy. its cutting that shape out that would be almost impossible to do without screwing something up... at least for me it would be
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-17-2004, 08:30 AM
Re: Re: Re: Re: Re: Silver Trim Rings
come on!!! you are not doing the job with an electrical saw !!! it wouldn't be that hard !
Default risk= max 3%
Old 12-17-2004, 08:45 AM
gsodonis's Avatar
No bickering, please.
Cutting it out straight is the hard part (if you try it by hand).
I'm going to attach an exacto knife blade to the tip of a compass and cut the masking ring out as I rotate the compass. Instead od drawing a nearly perfect circle only to mess it up cutting it by hand, I'll cut a near perfect circle with a compass. Problem solved.
All of this written (verbal) exchange helped develop the process, so thanks to all for the feedback and the ideas.
Old 12-17-2004, 10:15 AM
Word to Yo Motha
You know, I was thinking. (gotta stop doing that) The SVX speedo and tach can't be much different from other cars. There has got to be some standard, right? I bet there is one or two companies out there that makes most of the actual gauge faces....
Anyway, my point being, for the two main gauges, premanufactured chrome trim should work. I was looking, the sizes seem pretty similar to other jap cars. I may get some and see if they will work. I'll keep you updated.
Also, can you get exact dimensions of the circular gauges? I really like what you have done, but painting looks awfully hard to do. I don't have much of a steady hand.
Collin
1995 L AWD
Locker
Old 12-17-2004, 02:57 PM
Another option would be to go to a sign store and have them cut you a circle the correct size to use as a stencil.
