Old 12-16-2004, 04:39 AM
Blackbir2001
Rear wheel bearing
Can anyone provide me with the pat number or bearing number for the rear wheel bearing? Local Subaru agent are playing hard to get!
Dave@Partacoona.freeserve.co.uk
Old 12-16-2004, 12:31 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Try a US internet company like 1stSubaruparts.com or Motorsportwarehouse.com
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 12-17-2004, 06:46 PM
Re: Rear wheel bearing
Dave, you don't say what year your car is.
These are the parts numbers I used when ordering mine:
Rear Bearing [L or R] 28016PA010
Outer Seal [L or R] 906250020
Inner Seal [L or R] 28015AA021
Snap ring [L or R] 28035AA010
Hubs [L or R] 28052 PA010
If the person doing the job for you does not use a proper pullers, they can deform the hub, and new bearings inserted will fail quickly. Otherwise you should not need a hub.
Snap ring might be OK if you don't break it. They are cheap enough so maybe better get a new one. You DO need to get the inner and outer seal though.
Also, and VERY important, remove the packing grease the bearing comes wrapped in, and fill the bearing with proper bearing grease.
{Because mechanics kept installing the bearings with the packing grease, and the bearings kept failing, Subaru decided that all bearings would come wrapped in the proper grease. This happened maybe '99. Because you have NO idea how long the bearing they send you will have been on the shelf, carefully remove all the grease in it and pack with proper stuff before install. You have been warned}
Old 12-17-2004, 06:49 PM
Oh, and Andy is right.
Go onto www.subaruparts.com, go into SVX, quote the year, and check the part numbers I listed are correct. I think they will be.
Old 12-19-2004, 10:05 AM
joe2rule
Do you know the part number for the bolt that connects to the wheel bearing? Mine is rusted and has to be torched off.
The bolt is connected to the lateral links (if that helps).
Old 12-19-2004, 11:46 AM
Old Fogey
joe2rule,
If you mean the long bolt through the wheel bearing housing that attaches the lateral links it's; 20540AA000 with nuts;
20550AA010.
Glenn
Old 12-19-2004, 08:55 PM
joe2rule
YES! Thank you!
Originally posted by RojoRocket
joe2rule,
20550AA010.
Glenn
