Old 10-18-2004, 12:21 AM
tai
Angry plastic poo radiator
i you could buy a svx radiator without the trany cooler but made of all aluminum for 400 and a waranty would you
Old 10-18-2004, 05:43 AM
svx_commuter's Avatar
That sounds like a resonable price. There was someone awhile ago that wanted to have one make. They found a place that would do it and wanted to know if anyone was interested. My Plastic radiator blew apart from a slow head gasket leak. Well I guess the slow leak got a little faster when it blew.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-18-2004, 07:00 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Who's your source?
If you get the aluminum rad, let us know your source. Pictures of it pre and post installation would be great as well.
Old 10-18-2004, 07:15 AM
dcarrb dcarrb is offline
Considering that a new, plastic OEM radiator runs about $350, I'd say a $400 for all-aluminum wouldn't be unreasonable. Assuming your car still has the automatic transmission, just be sure the ATF cooler you use is up to the job. And be aware that, without an in-radiator cooler, you'll lose the cold-driving benefit of the fluid being warmed by the radiator coolant.
dcb
Old 10-18-2004, 09:56 AM
Peach
head gasket
Did you replace head gasket? How much for parts? You can't tell I'm expecting trouble, huh?
Old 10-18-2004, 10:32 AM
Re: head gasket
At the time my engine had about 150K miles on it. Based on time and money I choose to buy a used engine with 90k miles that I paid $800 for and put it in myself with a one warantee. That was about two years ago. So now I got 160k miles on the one I put in.
Old 10-18-2004, 03:17 PM
I'm still looking into getting an all metal radiator built for our cars. Unfortunately my first attempt failed because a copper/brass radiator is too thick to fit between the power steering cooler and the engine.
If it is to be done it MUST be aluminum.
Old 10-19-2004, 12:48 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Why not relocate the power steering cooler? What are the dimensions on that copper/brass unit?
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 10-19-2004, 01:07 PM
The biggest issue is that you can't drop the radiator in with the fans attached and you can't drop in the fans with the radiator in.
Now if the engine was out that might not be an issue but then you will have trouble installing the engine.
Old 10-19-2004, 01:09 PM
mohrds's Avatar
This may sound unreasonable, but what about installing it with the crank pulley, idler pulleys, belts, PS, Alternator, and AC compressor removed??
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 10-19-2004, 01:27 PM
It could probably be done but that's WAY too much work than it's worth.
I still have the radiator if anyone wants it to try to make it fit. I have some pictures of it I could post for those who are interested.
Old 10-19-2004, 04:59 PM
Brass/copper+aluminium=electrolysis.
Using dissimilar metals will lead to the aluminium corroding away around the water holes between the head and block.
Thats why they only use aluminium the water cooling system.
