Old 06-17-2004, 10:26 AM
svx_commuter's Avatar
Originally posted by SVXer95
I thought you wanted good gas mileage?
Most days.... and then there are those other days.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 06-17-2004, 10:29 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Those 'other days' happen to me all the time. That's why fuel consumption is never a concern for me!
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-17-2004, 10:52 AM
Chiketkd's Avatar
I went to Mike's site - subarusvx.org - and looked over his car. The only 1/4 he lists is a 16.5 he ran back in 7/02. The main performance mods he's listed are a Stebro exhaust and underdrive pulley. I doubt his is the fastest - it'll take way more mods than that to be the fastest NA SVX.
Green1995svx
Walter (poweredx2) had to do a crap load of work including porting his intake manifold, exhaust, disconnecting the pulley to the AC, intake and switching to smaller tires for better gearing. He may have done some other stuff as well...
-Chike
Originally posted by NomadTW
i would be willing to put money that mike davis (green1995svx) has the fastest NA svx on the network.
Old 06-17-2004, 11:32 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
that was a long time ago
he currently has a 1.8l impreza 5mt with a stage 3 spec clutch
the car tops out at 120 at redline in 5th
it's fast, very fast
SV What?
Old 06-17-2004, 11:50 AM
Chiketkd's Avatar
Tell Mike to take it to the dragstrip. I can't believe the 4.11 gears will top out at 120 in 5th, unless he made an adjustment to the gear ratios. My future 4.44 gears will top out at ~166 in 4th @ 7000rpm (after installing Longass's chip that will raise the fuel shut-off point)
Either way, it's hard to quantify seat-of-the-pants fast. Unless he runs his car at the dragstrip, it'll be impossible to say for certain that his car is faster than poweredx2's (or mine when my mods are done).
-Chike
Old 06-17-2004, 11:59 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
166 in 4th??
Somehow I don't think so.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-17-2004, 03:28 PM
Chiketkd's Avatar
Believe it. With the current 3.55 gears and overdrive 4th, our theoretical top speed is over 200mph!
The 4.44 gears raise the rpm level at any given speed by approx 500-600rpms. In 4th gear, with the torque convertor locked, with the revised fuel shut-off from Longass, it'll be doing ~166mph at 7000rpms.
PM Mychailo if you don't believe me - he's a mathematician and can break it down for you...
-Chike
P.S. To redline at 120mph in 5th, Green1995svx would have had to change the internal gear ratios in the tranny. He may have done away with the overdrive gear completely...
166 in 4th??
Old 06-17-2004, 03:35 PM
Word to Yo Motha
Theoretically possible? Yes. Actually Possible? Not so sure about that one.
Collin
1995 L AWD
Locker
Old 06-17-2004, 03:39 PM
Chiketkd's Avatar
I'm sure it'll be very possible. Sonar who has a 'stock' awd euro SVX with 3.70 gears has run to 267 km/h (or 166mph) in a timed event held in Sweden. If my SVX had 4.44 gears alone along with Longass's chip, I don't see why I couldn't do 165+ mph in reality - except that I'd have to find a race track to do it on...
-Chike
Old 06-17-2004, 05:45 PM
87f383's Avatar
87f383 87f383 is offline
-Chike
I know the computer on no car allows the torque converter to be locked at WOT. Unless you can circumvent that mechanically or by shorting the selonoid....it will not be locked on this "high speed run"
Old 06-17-2004, 07:19 PM
Chiketkd's Avatar
Good point.
However, the fuel cut-off with Longass's tuned ECU is 7400 rpms. I'm sure 160+mph will be very possible with that high of an rpm band to work with...
-Chike
Old 06-17-2004, 07:24 PM
Word to Yo Motha
Will the TCU let you get there?
Collin
1995 L AWD
Locker
Old 06-17-2004, 07:30 PM
Chiketkd's Avatar
Yup. The speed limiter is in the ECU. Longass removes it on his chip...
-Chike
Old 06-17-2004, 07:51 PM
NeedForSpeed NeedForSpeed is offline
How to 4.44?
That's awesome! I'm looking to build the fastest NA SVX on this forum, so I'll be taking my gearing a 'step up' to 4.44s. These gears along with Longass's chip, exhaust & intake should put me solidly into the 14's!
Personally, I don't care too much about gas mileage as I'm switching over from an SVT Lightning that got 14mpg in mixed city/highway.
-Chike
Chike,
If you really want the 4.44 gears, you might want to revive the last 4.44 thread. We still need some help!
Someone has to step up and tell us where to get the gears. Check it out, I don't know how to reference the thread.
Old 06-17-2004, 08:02 PM
Chiketkd's Avatar
Re: How to 4.44?
That's cool. I revive it in a little bit. On the advice of Mike (aka Rufus), a '96 Outback w/ a 4EAT will have 4.44 gears and with a 4.44 gear rear diff, the swap should be relatively straight-forward (i.e. no messing with the TCU). One thing, you'll need to swap the R&P gears out of the donor rear diff into the svx rear diff, to keep the LSD.
I really can't give too much technical advice, as everything I've learnt about these gears and this swap is from Rufus and Mychailo.
However, from what I've heard, the swap can be done!
-Chike
Originally posted by NeedForSpeed
Chike,
