Old 06-30-2004, 09:54 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
I've been using the Valvoline Synpower stuff too. stuff works pretty well so far as I can tell. I haven't noticed any fade even in spirited driving. I have SS lines too, so that counts for something. but the fluid seems pretty good.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 06-30-2004, 11:22 AM
wawazat??'s Avatar
Yeah, I'm still around
Originally posted by newsvx
tancred,
I don't think Chike is referring to "street racing", but rather autocross and perhaps at a local track.
I agree that street racing is just plain dumb. Without even considering that one could kill themselves or someone else, around here, if a person is caught street racing, the car is impounded and you go to jail. Just not worth the risk....
Harry
Thanks Harry, nicely put.
Todd
Down to none
Old 07-12-2004, 10:41 PM
UniqueAngle
I'd have the recommend the Motul 5.1
for my trip to Watkins Glen, we changed out the fluid to DOT 4 and that still didn't quite cut it. By the end of my first session on the track, the brakes were super mussy. Ended up cuttin' my track time short to swap fluid to Motul. Things worked much better after that.
~Brenda
Old 07-13-2004, 08:54 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chike,
Synpower here, too! While you're at it, why don't you switch to ss brake lines (oops, that's right, you did the tie-wrap mod ). Big thing is to make sure you bleed the brakes according to the suggest Subaru procedure (do a search on bleeding brakes...). It's really nice if you can get one of those pressure attachments for the master cylinder instead of manually pumping the brakes.
-Bill
p.s. remember "any bubbles are bad bubbles!"
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-13-2004, 09:06 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Bill,
Bring your bleeder when you come up on the 23rd. I'm have some interesting front brake lines that I'd like swapped in. They should be a direct fit for our cars and offer similar firmness to the zip-tied lines that I have on there now.
Plus, since they have a rubber covering on the outside, I'll be able to get away with them in G Stock SCCA competition.
-Chike
Originally posted by SVXRide
Chike,
-Bill
2006 Steel Gray WRX TR (sold)
Old 07-13-2004, 09:27 AM
SVXRide's Avatar
Chike,
Trans/Diff swap out AND brake line replacement all in one day? I'm going to have to check for the big S on your chest and Mike's
-Bill
p.s. I'm hopefully going to be able to nail down the "why no AWD" issue this weekend while I'm replacing the radiator...
Old 07-13-2004, 09:32 AM
Chiketkd's Avatar
Good luck! look forward to seeing you on the 23rd...
-Chike
