Old 05-21-2004, 09:28 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Strut Mounts
Not sure if this is in the right forum...
What is the difference btw the two front strut mounts listed here:http://www.subaruparts.com/diag/?mod...category=210-1 ?
Anyone know of a better (read: cheaper) source for these?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-21-2004, 10:12 AM
svx_commuter's Avatar
I think that would be the original less stiffer mount and the redesigned stiffer mount.
No other less costly alternative.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-21-2004, 11:17 AM
mbtoloczko's Avatar
sans SVX
1stsubaruparts.com might be a little cheaper. They also accept AMEX which is great if you have a Skymiles AMEX. :-)
Mychailo
Visit my locker
Old 05-22-2004, 06:31 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
WHA?
What stiffer mounts? When were they introduced? Why were they introduced? Was it just front or was it rear too?
Old 05-22-2004, 10:05 AM
mbtoloczko's Avatar
sans SVX
The front strut mounts for the '92-'93 cars would make a clunking sound on bumps. The front strut mounts were modified to stop this. This is what they're talking about.
Mychailo
Visit my locker
Old 06-10-2004, 02:52 PM
Out of curiousity I checked and there's 3 different SVX strut mounts:
on the 1995 SVX there are 20320PA001 and 20320PA010 but for the 1992 there is 20320PA011 (which I would assume to be newer)
Old 06-10-2004, 03:10 PM
Word to Yo Motha
When I ordered the struts they gave me the 20320PA011. My guess is that no matter what you order now, it is superceeded to the new part number.
Collin
1995 L AWD
Locker
Old 06-10-2004, 09:00 PM
svxpert svxpert is offline
part #
you would recieve part #:20320PA011
i can get the OEM ones for you at $55 each $110/set $7.00 shipping USA.
Old 06-10-2004, 09:54 PM
Old Fogey
I'll take a pair!
Let me know how. Clunking front end's about to drive me nuts, and a new set would be in order with a set of Koni inserts. Thanks!
Glenn
Old 06-11-2004, 06:44 AM
Word to Yo Motha
Re: part #
Wish you would have seen this a few weeks ago. I spent akmost twice that.
Collin
1995 L AWD
Locker
Old 06-11-2004, 08:10 AM
red95svx
That is correct. The original strut mounts that were used in SVX's until April of 92 were changed slightly to prevent noise. From then on, all SVX's used the same mounts, and the original style mounts became un-orderable. This is also why the 92's had different part numbers for the front struts. Those changed too.
Old 06-11-2004, 08:22 AM
red95svx
There are actually 4 different numbers. The PA000, PA001, PA010, and PA011. They all supersede to the PA011. The PA000 changed to the PA001 in April of 92 to help with the noise problem (then came the strut change). As far as I know the PA010 and the PA011 were just part number changes, not actual design changes.
Old 06-12-2004, 12:25 AM
NeedForSpeed NeedForSpeed is offline
What Strut?
An internal change on the strut?
Does it matter what strut is used when upgrading to Koni inserts?
Old 06-12-2004, 05:46 AM
red95svx
Re: What Strut?
I'm not sure what was changed. All I know is that if you had a SVX with the 1st strut design and you needed to replace a front strut, you had to replace both at the same time with the new design. If you only changed one to the new design the car would not sit correctly. Yes, I know, some people say you should always change both struts at the same time anyway. My point is even if you only wanted to change one you couldn't!
It shouldn't matter which strut design you have when you upgrade to Konis.
