Old 05-19-2004, 09:32 AM
lee lee is offline
Engine info - something new I learned
Maybe you folks all knew this...I didn't.
Seems Subaru does not necessarily install the same sized pistons from the factory in any one given engine. Now maybe I'm wrong, but I think this is a pretty unusual practice. Does this work because of the inherent balance of the boxer engine?
Anyway, I post this as a caution for anyone thinking of a home rebuild...also might want to provide the info to whatever rebuilder you use if having the job done professionally. Seems like it would be of interest to those balancing/blueprinting as well.
So for you shade tree mechanics, watch which cylinder the piston came from...my reference is:
http://www.endwrench.com/pdf/engine/...esInfoSp00.pdf
Old 05-19-2004, 09:36 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Do they match-grind the piston and bore?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
svxsubaru1's Avatar
So ever cylinder has a diffretn size piston? I never heard of this before, who told you this?
Old 05-19-2004, 09:45 AM
lee lee is offline
Not necessarily, click on the reference and read Subaru's own words
Old 05-19-2004, 10:20 AM
svx_commuter's Avatar
This is clearly stated in the FSM. The pistons are given a grade letter and then the letter is stamped on top of the engine block for each piston. The clearance between the piston and cylinder is very tight on the SVX. That is why the piston has to be matched to the bore. I think it also a good part of the reason as to why the engine is so quite.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-19-2004, 10:38 AM
red95svx
Subaru has been doing this for a while now on all its models. The "grade" of piston and its location in the block is stamped on the top front of the block. You can not mix and match.
Old 05-19-2004, 11:59 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Probably a major reason why the engines last so long -- looks like we get a blueprinted engine from the factory!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-19-2004, 04:10 PM
wawazat??'s Avatar
Yeah, I'm still around
-Bill
According to the R&T guide, each EG33 was also dyno tested prior to mounting in the car to ensure performance.
Down to none
Old 05-19-2004, 04:53 PM
manufacturing tollerances.
The bore and piston sizes vary with manufacturing tollerances. Most engine builders selectively fit pistons to bores. Some selective fit crankshaft, slipper bearings also.
Old 05-19-2004, 05:25 PM
Word to Yo Motha
Yet another reason why so few were made and the price was so high....
Collin
1995 L AWD
Locker
Old 05-19-2004, 07:05 PM
Now I got the FSM here in front of me. The clearance is .0004 to .0012 inches diametrical.
Bore size Piston Grade/ Cylinder bore / piston sizes follows:
A 3.8151 to 3.8155, 3.8144 to 3.8148
B 3.8148 to 3.8151, 3.8140 to 3.8144
C 3.8144 to 3.8148, 3.8136 to 3.8140
I wonder if they did this on the piston slapping 2.5 engine?
Old 05-19-2004, 07:29 PM
Word to Yo Motha
Wow, six tenths max clearance. Not bad, not bad at all.
Collin
1995 L AWD
Locker
Old 05-19-2004, 08:05 PM
lee lee is offline
Re: manufacturing tollerances.
Harvey, I haven't wrenched professionally since 1972, and that was on traditional American iron. I can assure you that in my part of the the US there was no piston matching 30 years ago - except maybe for serious blueprinting work. Although with the advent of Plastigauge, there was some crank/rod bearing matching by the better shops and by most hot-rodders.
Are you saying most auto/engine builders do this today, i.e., Toyota, or is this something modern, and good, rebuilders do?
Old 05-20-2004, 05:50 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
On grade A you are looking at a .0003 thru .0010 tolerance
On grade B you are looking at a .0004 thru .0011 tolerance
On grade C you are looking at a .0004 thru .0012 tolerance
those are pretty tight to hold on a cars engine. That is very impressive considering that a human hair on average is .0035 thick.
No wounder the EG33 runs so smooth.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 05-20-2004, 08:43 AM
deruvian
SVX-FF, what's with you and the cicadas?
