Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 03-14-2004, 10:25 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
charger questions
Will a turbocharger or supercharger raise compression ratios? Out of the two, which one is more economical or affordable.
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 03-14-2004, 11:13 PM
mbtoloczko's Avatar
sans SVX
Neither change the compression ratio, but it doesn't matter. Both put additional stress on the engine, and if not tuned properly, the additional stress is great enough to cause engine damage. Since there is no street-driven supercharged SVX (that I know of), and there has yet to be a properly done street-driven turbo SVX, no one knows which provides the most performance and reliability per dollar.
Mychailo
Visit my locker
Old 03-14-2004, 11:16 PM
ww111
Nothing external will change your compression ratio. CR is a very simple calculation between the volume of the cylinder at BDC (Bottom dead center) and TDC (Top dead center).
Atmospheric pressure is (about) 14.7psia (Pounds per square inch absolute) at sea level. or 0 PSIG (Gauge) i.e. 1 atmoshpere
If you double that with a turbo (14 lb's of boost) in theory you double the HP. as far as economy, you'll need to define the term a little better. drag racing=supercharging Anything else=a turbo is generally a better option.
Collins
