Old 04-28-2009, 08:28 AM
Splinter Splinter is offline
Re: Best way to clean engine bay???
I use simple green when the motor is cold, a very thorough wash down, followed by a spray of armorall, then a wipe down and another rinse.
I never cover up anything. Never had problems. YMMV.
Old 05-09-2009, 09:19 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I think I'm just going to hire someone to do it for me..
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 05-09-2009, 09:43 AM
I have a very low pressure - pressure washer. It will not damage hoses or belts. I usually cover the alternator with a grocery bag to keep heavy spray off of it. I spray a degreaser on the heavy greasy areas if there are any and let it soak for a while. I use hot water with the pressure washer and then spray everything which takes most of it off. I then repeat on the bad areas again. It usually does a great job removing all of the oil or grease in the whole engine bay. I then wipe everything down and use back to black on the hoses and black parts. I usually wax all of the painted surfaces.
Old 05-09-2009, 09:54 AM
Freeman's Avatar
Unregistered User
Of course you do.. I'm coming over to play with your toys! Lol
Old 05-09-2009, 10:32 AM
Bring it over and we can get it cleaned up so you will proud to open the hood.
