Old 01-29-2004, 11:48 AM
Green1995SVX
Big 5 speed problem. No Speed Sensor?
I was just called by the shop doing my conversion. The transmission I got apperently doesnt have an electronic Speed Sensor. (1996 Impreza) Is this possible? What can I do at this point? If I buy another transmission I fear I wont have enough money to bail my car out of the shop.
Mike
Old 01-29-2004, 12:04 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
How can it not have a speed sensor? Something needs to tell the speedo where to be.
Old 01-29-2004, 12:18 PM
Green1995SVX
It uses an analog signal through the use of a cable. I learned (thanks huck!) that it's possible to convert it to a digital output by bolting the svx vss onto the manual box.
Mike
Old 01-29-2004, 12:25 PM
Mr. Pockets's Avatar
Moderator
So the SVX uses a digital speed sensor signal, but some other trannies used an analog signal? Weird. I mean, I would expect the digital signal to be more accurate, but it's odd to me that they used both for awhile.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-29-2004, 03:36 PM
Green1995SVX
Sorry, a more accurate term would have been that the impreza tranny uses a 'mechanical' signal.
Mike
Old 01-29-2004, 03:46 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
That's what the tater's for!
Sorry. Couldn't resist.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-29-2004, 04:00 PM
Moderator
Mike
Ah - I get it. Since the AWD setup in your Impreza donor wasn't an electronic VTD setup (like the SVX), it doesn't need a digital signal from the tranny. So you can retrofit the electronic sensor from your original 4EAT into the 5MT?
2005 Outback
END OF LINE
Old 01-29-2004, 08:49 PM
Green1995SVX
Here is what was attached to the MT:
http://www.subaru-svx.net/photos/fil...5SVX/14613.jpg
This shows the SVX Digial VSS mounted in place of the cable on the MT:
http://www.subaru-svx.net/photos/fil...5SVX/14611.JPG
It was a direct bolt on. It took me about a minute to do this afternoon.
Mike
Old 01-30-2004, 05:44 PM
Subafreak's Avatar
Superbeast
In the SVX it takes the speed signal from the tranny and uses it to control the speedo, the ECM input, and the TCU input. When you convert it to a 5speed you still need the signal for the speedo and the ECM but the TCU is not used anymore. On the earlier Imprezzas and Legacys they used a regular speedo cable to operate the speedo and the speed sensor was built in to the speedo in the dash. Thankfully when Subaru made the speed sensor for the SVX they just made it screw rite in to the regular cable hole. Thank you Subaru.
And no Huck, not that kind of speedo
Old 01-30-2004, 10:27 PM
GreenMarine's Avatar
From POST-***** to LURKER
Just why would ya think that Huck would think about "that kinda Speedo"???
Old 01-31-2004, 06:38 AM
wawazat??'s Avatar
Yeah, I'm still around
So I'm guessing this is the reason you called the other day and you're all set???
Todd
Down to none
Old 01-31-2004, 08:25 AM
Green1995SVX
Todd
You are correct sir. I was panicing for a bit.
Mike
Old 01-31-2004, 11:31 AM
Subafreak's Avatar
Superbeast
Huh? Did I say Huck I ment Randy Wow, I must have been really tired last night. No really, I was just tired.
No hard feelings OK Huck?
Old 01-31-2004, 12:33 PM
use the differencial case off your svx trans abd use the speedo gear and origonal sensor
Old 01-31-2004, 02:18 PM
Aredubjay's Avatar
I'll apologize to Huck, also. I hate to see him insulted like that (confusing him with me, not mentioning the speedo).
Well, it must be that we're both from Kentucky, that caused the confusion.
Randy Johnson
