Old 06-10-2004, 09:41 AM
Originally posted by tancred
Also on topic...is there a specific tranny filter that will work better then others? i looked at mine and for a tranny with 30k miles on it that filter looks like its been on there for about 120k miles...lol...
looking to replace with something not subaru oem..
Permacool external filter - makes adding a temp gauge easy, too - it has a receptacle in it for the sender.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 02-12-2006, 07:25 PM
drivfour drivfour is offline
trans cooler- how to remove center light bar
excellent data- I am installing B&M cooler- removing light bar not obvious, Can someone explain how to remove
Thanks
Originally Posted by halistan
I have installed (Kuo and I actually) tranny coolers on 3 SVX's. a '92 and 2 '93's (mine and kozypups). On all three we installed temperature guagues on the SVX's before we installed the coolers. Here is the data.
Kuo's 92 - temp was in the mid 90's
I don't remember the brand we used but it was a little smaller than the B&M supercooler used on the other SVX's. So we installed two of those coolers in series and bypassed the stock cooler completely. On this one we put then between the condenser and the radiator.
Before the cooler he was running 200 degrees on the highway with jumps up to 240 on the city roads
After it dropped to 180 highway and rarely gets above 210 in the city
Both my and Marisa's SVX's: 93 limited edition.
We installed the B&M supercooler in front of the condenser (see picture) The bumper doesn't need to be taken off. It fits perfectly where you see it. Just slide it in and use the little ties that come with it to secure it in place and run your lines.
Before the cooler we ran over 200 degrees all the time with it jumping to 220-240 in the city. The thing about it is once it got hot (230-240 range) it just about never came down.
After installing the B&M cooler our temps dropped to about 165 almost all the time. There are times it gets up to 185 on very rare occasions. In the wintertime i have noticed that i have rarely takes more than a mile of driving before the tranny warms up enough (50 degrees) for it to engage 4th gear. It gets pretty cold here in KC..sometimes its well below zero and I still have never had a problem in the 3 years its been since i installed it.
If you want my opinion...go with the B&M Supercooler, install it in front of the condensor and be happy Its perfect. Oh, it only takes about 45 minutes to install.
Old 02-12-2006, 10:24 PM
dwd1985 dwd1985 is offline
I just installed my permacool filter yesterday. It actually took longer then I thought. Mounting it wasnt bad, the hardest part was figuring out which line was the supply line, and then managing to pull the old hoses off of the metal lines. Havent gotten around to doing the guage yet. But the filter seems to work very well.
Old 02-13-2006, 01:50 AM
dmnknightomega6 dmnknightomega6 is offline
Can someone please post pictures of the lines? thanks!
Old 02-13-2006, 02:53 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by Mr. Pockets
1. I put it in front of the AC condenser because clearly there's good airflow at this location. It also fits neatly .......
Which cooler did you use Nick? I tried to follow your recommendation when I installed a B&M 70268 on our '94, but I could not make it fit.
I removed the whole bumper in the process. It seemed like there was about an inch of space in the centre, but it narrowed to about quarter of an inch at the sides. How on earth did you make it fit? Is your cooler smaller?
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-21-2006, 10:18 PM
nexus_7 nexus_7 is offline
just ordered the B&M 70268 this should be intreasting.
Greg
