Old 01-20-2004, 02:29 AM
The Molinator
Bearing Type Whine . . . . .
I replaced both the front and rear bearings last year. After replacing the rears early last year, I still heard a whining sound which seemed to come from the front. Later in the year, I replaced the fronts, but I still hear at times a definite (slight to moderate) whining sound. I don't think either front or rear bearings were done incorrectly nor do I think they've gone bad right after the replacements were made (as some say is possible: bent hubs, lugs overtightened, etc.). My best guess on the rotation rate on the rotational whine is at a faster rate than the wheels (?). Could it be the driveshaft U-joints? [I replaced the front axles (one bad boot) late in the year also.]
What do you think could be making this haunting whining noise?
THANKS for any help!
Jim
Old 01-20-2004, 10:36 PM
TorG0d
Try some new tires. My Dunlop Sport FM-901's whine a bit . . .
Old 01-21-2004, 02:13 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
I do know that transmission end bearings can cause what you are describing, but I'm pretty sure thats not what you want to hear.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 01-21-2004, 03:33 PM
The Molinator
WHINE
It's not so much of a (constant) whine as it is a "Yah!...Yah!...Yah!...Yah!" cyclic type of sound. It seems to be faster than the rotation of the wheels, so might be driveshaft, front differential rear bearing, rear differential front bearing, etc.
I guess it could be the rear trans bearing? I'm gonna hafto find a wing-walker that wants to be strapped to the undercarriage (very thin person!) of the SVX while I drive around to diagnose the problem!
THANKS for your input!
Jim
