Old 01-18-2004, 06:45 PM
gamblergw
Air out dash vents
When i put my climet control on auto or any other position, I dont get any air out the dash vents. The air seems to work fine but all the air is below the dash. Nothing coming out the dash vents. I have checked to make sure they are open.. Any answers? Jim
Old 01-18-2004, 07:26 PM
Ralph Gibbs Ralph Gibbs is offline
heater/cooler air vents
Hi Jim, there was some discussion on heating/ cooling not to
long ago. For a/c I get air in the face from the vents. Here in the
great white north we are experiencing -25 to -30 c at present and the hot air blows from the floor. I did try something when the SVX was nice and warm. I changed the temp. from 23 c to 20 c
and what happened was this; the SVX called for cool outside air and it came through the vents on the dash.
Hope this helps you........Ralph
RGG
Old 01-18-2004, 08:52 PM
gcookaustin
Well, seeing as how you're in AZ...
Do a search on the board for this topic. You'll find you can look to the right under the driver's footwell at the climate control levers that move to control the vents. One may appear to get stuck part of the way. You can move it by hand to free it, and apply some sort of grease or something to the track.
Old 01-18-2004, 11:04 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Heat will not come out the dash vents. The engineers of the SVX designed the system NOT to blow out the vents. Heat is directed to the floor and a bit to through the windshield vents, but not to the dash. The reasoning (or so I've read) is that the Subaru engineers decided that the air, coming out of dash vents, dried the driver's eyes out. Since heat rises, they figured that the car would warm nicely without sending heat to the dash.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-18-2004, 11:32 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
Hmm...I have been having the same problem! The no heat through dash vents idea is very logical though
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 01-19-2004, 12:09 AM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
But heat will come out of the dash vents on non-US models. Did the Subaru engineers not care about non-US drivers?
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 01-19-2004, 11:52 AM
gamblergw
air not heat
Its not the heat i am worried about. Its the air conditioning i am concerned about. I am in AZ and it does get HOT here... Thanks guys.. I will try to check under the dash for the control you are talking about..... Jim
Old 01-19-2004, 11:59 AM
Aredubjay's Avatar
Re: air not heat
Duh! Sorry, man, I'm spacin'.
Either the actuator is getting weak, or the door is getting stiff.
The actuator you'd be looking for is under the dash, on the driver's side of the tranny tunnel, just under the radio/cd player position. Shoot the linkage with a little silocone spray (I use WD 40 but have gotten hell for it, so I won't suggest it unless you're comfortable with the "bouquet" for a short period of time). If shooting the linkage doesn't do the trick, the actator may have gone south which is NOT an inexpensive fix, sorry to say.
Randy Johnson
Old 01-19-2004, 01:51 PM
gamblergw
thanks Randy,, will try that...... Jim
Old 01-19-2004, 02:47 PM
gamblergw
works now
Rabdy ,I just went out and looked under the dash and found the lever and moved it and it came un stuck.. Works fine now. Thanks again.....jim
Old 01-19-2004, 03:08 PM
Aredubjay's Avatar
Re: works now
Excellent! Welcome to "in your face" (pun intended) SVX fun!
Randy Johnson
