Old 01-13-2004, 09:59 PM
njboys808
Speed Sensor
Hi Guys. I need to know the part number for the speed sendor that goes inside the front differential. I have to replace mine. Thanks!
Old 01-13-2004, 11:32 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
www.subaruparts.com
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 01-13-2004, 11:44 PM
njboys808
No help
I know all the subaru websites but what I need is the part #
Old 01-14-2004, 08:30 AM
mbtoloczko's Avatar
sans SVX
Re: No help
If you go to subaruparts.com and hold your mouse over the link to the part that you need, the part number can be seen in the link description at the bottom of your browser window.
Mychailo
Visit my locker
Old 01-14-2004, 09:12 AM
njboys808
Still no help
I know all about how to use subaruparts.com. But I can not locate the part on their site. What I'm looking for is someone that knows the part#.
Old 01-14-2004, 09:32 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
http://www.subaruparts.com/diag/?mod...category=835-A
85082PA010 Speed Sensor Ay $146.91
Have you tested it to make sure it is the sensor? Mine went out and it was the little metal "T" pin the spins inside the sensor. Others have had the nylon gear inside the diff go. I'd hate to have you drop the cash to replace a part that is still working.
There is also an electrical test that consist of checking for voltage across two of the terminals and a on/off/on/off signal on the third when you turn the shaft inside the sensor.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
