Old 12-30-2003, 12:04 AM
Wocketman Wocketman is offline
Unhappy Driver's window switch
Ok, SVX newbie here....needing some simple sage wisdom:
My driver's side window switch has ceased functioning and is very wiggly anyway. Has anyone pulled off a simple repair or is it time to buy a new main window switch assembly from a dealer (ouch$!). I'm bummed since it was working pretty much ok when I bought the car a couple months ago...but it felt like it was getting loose. Oh well!
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 12-30-2003, 12:39 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I did a howto clean that ages ago. I am not sure if it is still there. It's very easy to do and clean it first. Then get a replacement.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 12-30-2003, 11:08 AM
SubaSteevo's Avatar
No longer blue member
Cleaning it is probably not going to solve your problem, but I have fixed mine another way. The way the switch works is it pivots back and forth like a seesaw and on either side there is a peg that is pushed down. What happened to my switch was the clip that held the switch on one side of the seesaw snapped. To fix it I took a paper clip, heated it up, and then stuck it through the side of the switch to create a new pivot point. I posted a mini how-to somewhere, you could try searching my sn for "window switch fixed" or something like that. New switches will run you about $100 shipped from subaruparts.com depending on whether you want the one from a 92 with auto up/down or a later one with only auto down. My auto doesn't work at all, but I can live with that for $100.
-Steve
01' MSM Lexus IS300
Old 12-30-2003, 11:45 AM
Steve
If you find the mini how to, let me know or send it to me. I will post it in the How-To locker. To email it to me - click on Earl below and that is my email address.
Thanks
Old 12-30-2003, 12:02 PM
I did the search and found it. Thanks
Old 12-30-2003, 04:14 PM
Thanks gang!
So I'm hoping you're going to post that How-To thread? Of course any pointers or warnings on getting the switch out of the door in the first place would be good.... I certainly don't need to break more stuff than I fix!
Bruce Schwab
www.bruceschwab.com
Old 12-30-2003, 07:29 PM
SubaSteevo's Avatar
Originally posted by Wocketman
Thanks gang!
Here's the link:
http://www.subaru-svx.net/forum/show...=window+switch
To get the door panel off their are two visible screws near the hinge. Under the handle there is a plastic cover, pop that off with a flathead and there is another screw under there. If you pull up the felt inside of the hole in the armrest there are three more screws. After all screws are removed, pull on the bottom corner of the door near the light to pop off a couple of clips, then you need to pop off all the other clips on the bottom and side, then lift the panel straight up to pop the clips near the window (you will need to use some force, but just don't forget there are wires holding it in place). There are two bundles of wires plugged in, there are little tabs on the connectors to disconnect them. After you have the panel completely off I think there are four small screws to take off the switch cluster. You can use my paperclip method to fix it if you like, but once it's off you may be able to figure out a better solution. Good luck.
-Steve
01' MSM Lexus IS300
Old 12-30-2003, 07:56 PM
Thumbs up
"Much Garcia!"
(Norcal Dead-head for thanks...)
Got the door off, the switch apart, and discovered that the plastic switch "knob" had split it's little receptacle that holds the tiny actuator for the "real" switch below that. Several efforts with super glue couldn't hold it together, so I used a combo of glue and a tiny screw tapped in from the top of the knob (I can live with a tiny phillips head screw under my finger when using the knob) that goes into the little actuator. Got it all together and it's working great! Don't know how long it will last but at the moment I'm quite full of myself....
Bruce Schwab
www.bruceschwab.com
Old 01-03-2004, 05:27 PM
Glue has worked for me so far. I've fixed 4 switches and so far only 1 has caused additional problems.
Old 01-05-2004, 11:07 AM
poweredx2 poweredx2 is offline
simple solution
Just disconnect one of your rear window switches wiring from the driver control panel and wire the driver side to the rear switch,bam works like new.
Old 01-05-2004, 12:39 PM
SubaSteevo's Avatar
Re: simple solution
Except everytime you put down your drivers window (to pay a toll for example) both windows would go down
-Steve
01' MSM Lexus IS300
Old 10-03-2011, 08:07 AM
dromano's Avatar
dromano dromano is offline
Re: Driver's window switch
Can you send me the link? My driver switch will open the passenger window, won't close it, have to use the passenger button to close.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
