#31
Need help identifying some wires:
I've attached a pic with the 4 wires in question but here are the details: The pic was taken of behind the driver's side kick panel (note the 2 blue wires ) 2 of the wires are black w/white stripe so I'm thinking that a previous owner wanted the clip for elsewhere. Is this for the °F<->°C conversion or is that under the passenger side kick panel? If this is not that plug then what is it? One wire is blue w/white stripe and has the "gold" color plastic end on it. Any idea what that's for? The last wire is just black and no stripe (at my middle finger in the pic). It's just cut off and I can't find the other end to it. I wish I had a service manual...and the neck of the previous owner!! Thanks for any and all help you can provide.
#32
I think alot of the wires over there have to do with the prewired cell phone option. I think it is strange about the wire that just looks cut off thoe. Why are you wondering anyway? Do they have anything to do with the swap or are you just wondering?
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
#33
I was just wondering about the wires, that's all.
I'm trying to keep everything as neat as possible. I know that most of my car has been taken apart at least once by the previous owner by evidence of taped up wires, broken plastic, incorrect clips/bolts/nuts/screws... When I take apart anything I'd just like it to go back together the way it's supposed to. (my driver door panel likes to pop off on the back top and it annoys me)
#34
Well we're making more progress on the conversion. Yesterday and today we've adjusted and installed the shifter. Our goal was to have the shifter centered in the trim panel opening so that cutting the trim would be avoided.
The driveshaft is also installed thanks to a friend of my dad's who fabricated the extension for the shaft. We put the axles back in and we're currently working on the large heat shield so that we can put the exhaust back on. We're still trying to find where we misplaced the exhaust hanger. Still to go is most of the wiring for mostly everything as well as basic reassembly. It's starting to get exciting as the project end is close at hand.
#35
Glad to hear it's getting close.....
#36
Nice going David (and Norm)
I got my driveshaft modified (to avoid the extension and to still use the SVX center mount location) and tomorrow will be picking up the custom step-down stud (12x1.25mm-35mm long to 10x1.25mm-20mm long)I had made to avoid modifying the starter. Once the shaft is in, the car hits the ground for the first time in months. Then pedals, hydraulics, and electrics.
Todd
Down to none |
#37
WOW. Davids blowing you away Todd, you better get cranking on that conversion, the pedals are the worst part ya know.
#38
I'm sure Todd just doesn't have the spare time to work on his car. I took over a week off work to work on mine.
I just picked up some plugs today that I cut off a junk wiring harness to use for my clutch pedal switches. I'm still waiting for the 3 clips I ordered to hold the fuel lines along the driver's door.
#39
A blind man with no arms would be fastAr than me Jesse. I just want to beat Doug and I'll be happy. Todd for your support
Down to none |
#40
It's also not my main mode of transport, so luckily I'm not pressed to get it moving. Todd
Down to none |
#41
I am gathering the parts for the conversion and I got a WRX transmission + all the goos stuff.
From what I understood the WRX has the same final drive ratio so there is no need to swap the rear differential. Could you gentlemen confirm this? |
#42
The 2002/2003 WRX for sure has a 3.90 front diff but because of the 1.1:1 center diff it uses the same 3.545 rear diff.
I figure RPM's at 60mph with this tranny should be under 2400.
#43
USDM WRX is a go. JDM WRX is a no go.
#44
Got another question for the 5 speeders:
There's 2 plugs coming out of the transmission (aside from the speed sensor). I know one is used for the reverse lights but what is the other one for? (both have 2 wires)
David B. SVXipedia @ SVX-IW.COM -- SVX Information Warehouse 2.0 coming...eventually! Ebony 1992 SVX LS-L 5 spd Koni/GC Stebro 187k miles RIP (Rust In Pieces) 1993 SVX 5 spd Koni/GC Stebro Polyurethane bushings still available! Last edited by Earthworm; 12-31-2003 at 10:23 AM. |
#45
the other plug
The other plug is for the neutral switch. I believe it is closed except when in neutral.
Hope this helps and sorry I missed you in the chat room. Jay
Speed Safely Subaru, All We'll Drive Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07) Laguna Blue '94 L about 130Kmi (I think) for parts, in storage previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else) previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed) Black '89 XT6 5spd AWD (storage) |
