Old 11-05-2003, 08:20 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Bad Shift Points
Automatic Transmission Before rebuild:
1st: 45mph/6500rpm
2nd: 80mph
3rd: 130mph
After rebuild:
1st: 40mph/6150rpm
2nd: 75mph
This sucks! Gained much time on 0-60. Took it back and tranny place said nothing they did would affect my shift points. I tried removing resistor but that didn't help. Does anyone know how this happened or how I can fix it?
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 11-05-2003, 09:00 PM
subafan subafan is offline
not just a fan, a Member!
um... this may sound simple, but sometimes the simplest things are overlooked... are you in power mode??
svx: the most effective diet (distant memory)
mr2: diet on the diet (on the chopping blocks)
urs4: looks stale, but good performance... hoping this one will last.... but too bad it didn't
mrspyder: gotta have a drop top in cali...
always looking for a reliable 5spd svx...
Old 11-05-2003, 09:17 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
If you find out how to change the shift points, be sure to tell us!
I know most of us wouldnt mind shifting at 7k
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 11-07-2003, 11:04 AM
Yoda3000's Avatar
Yes, I am in power mode. I even put it in first gear manu. mode to make it shift a little higher but it's not nearly as good as it used to be.
Old 11-07-2003, 11:30 AM
mikecg's Avatar
mikecg mikecg is offline
I think mines does from 1st to 2nd. I think it bounces off the rev limit right before it shifts if I mash it on take off. She gettes a strange crackle from under the hood then shifts. I havnt acually caught the position of the tach. I hear the noise and by the time I look down at the tach its at about 6200 and coming down.
Old 11-07-2003, 12:20 PM
Mr. Pockets's Avatar
Moderator
Yoda, what year is your SVX? Did you have a Subaru remanufactured tranny put in your car, or did the shop rebuild your old one?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-07-2003, 05:10 PM
Yoda3000's Avatar
My car is a '92 LSL. I had the original automatic rebuilt at a non-subaru transmission shop. Budget Transmission Masters.
Old 11-08-2003, 03:30 PM
mikecg's Avatar
ok I acually looked this time. It shfts at 6500. I also noticed hat I cant get the power light to come on if the shifter is in 1st. Is that normal??
Old 11-08-2003, 07:47 PM
You should be able to engage power mode in any gear simply by releasing the gas pedal then flooring it.
Some people also floor it twice but I find that unnecessary.
Old 11-09-2003, 09:41 AM
mikecg's Avatar
Ya I tried that. The double tap on the gas works. You dont even have to push the petal very far if you double tap. I just cant get it to wrkin 1st. It works in all the rest of the gears.
Old 11-10-2003, 04:51 PM
Yoda3000's Avatar
The day I got my car out of the shop the alternator died and I got that replaced at our local dealership. You don't think that could have affected the shift points do you?
Old 11-12-2003, 06:28 PM
Yoda3000's Avatar
What're you guys's shift points for comparison. I did a 0-60 today at 9.3.
Old 11-19-2003, 03:05 PM
ALCYTWO
This may not be helpful since I know nothing about the Subaru tranny yet, but I had an 86 Jag 6 cylinder with automatic transmission, and the shift points were adjustable. Not through any obvious means, but through a cable adjustment that the book said was to compensate for band wear. Playing with that would make the trans shift either WAY early, or not at all. Setting it just right got it to shift just before redline.
Maybe the Subie has something similar?
Craig
Old 11-25-2003, 11:02 PM
Yoda3000's Avatar
That acually helps a lot and makes a lot of sense. When I got my car back the shift indicator was off from the P,R,N,D,3,2,1 windows by the shifter by like a quarter centimeter. When I took it back they said they didn't do it and they couldn't fix it. (Lying B*st*rds!) Do you think the cable to the shift lever could be related? I'v been meaning to tear it apart and see if i can adjust it.
Thanks a lot Craig.
