Old 12-04-2003, 08:47 AM
JoesSVX
Sensor location
There are two sensors, but one is called a thermometer and is for the guage in the instrument cluster.
A separate sensor is for the computer.
Both are located on the driver's side of the engine at the top at the rear. The beauty is that you should get virtually no coolant leakage when you remove it because of it's position.
If you are getting a low (and inaccurate) reading on your guage, I don't believe it will affect engine performance.
Old 12-04-2003, 08:49 AM
AFBeefcake's Avatar
Subaru Swapper
I don't think both temp sensors are the same. I think there are too the right of the throttle body and under the intake manifold.
2005 Legacy GT
My WRX's Cardomain Page
Old 12-04-2003, 02:21 PM
6evil9
anyone can provide the pics of location of temp sensors?
does the subaru.parts.com have the pic and parts numbers?
ok so there are 2 sesnsors and u can see that gauge one is bad just because u have strange readings, but u never can check the computer one... right?
Old 12-04-2003, 11:53 PM
6evil9
ok another idea: the manual says that if u got rough idle check the connecters to ECU first (power of ECU)....
maybe its not a bad idea? so its the ECU which controls RPMs at idle (as it can be issue for me)
so anyone with ideas where i can find it? maybe it can help...
as i ve been all around the car with my *magic* (khe khe) hands
coz i dont believe its fuel pump or anything serious... if its fuel pump or regulator they would be already dead...
cheers
Old 12-05-2003, 08:37 AM
JoesSVX
ECUs are under the dash on the driver's side. If you lay on the floor looking up, you'll see a neat row of four units with two-high connectors running to them. That's them.
Also, the main relay is just aft of them in the center. It's the brown one and you'll feel it click when you put the key to "ON".
Old 12-05-2003, 10:41 AM
immortal_suby's Avatar
Thread Killah
Check my locker for a picture of the ECU location.
Locker Link
2015 BRZ Limited 6MT
Old 12-05-2003, 04:22 PM
Fortunately the problematic temp sensor is the cheaper of the 2 sensors. It's the one with 2 wires connected to it.
Old 12-05-2003, 05:54 PM
6evil9
cool
ill check the connectors of ECUs...
any ideas if they can be reset to factory? maybe it could help
bout temp sensors... anyone got a pic by any chance? that could be cool... but ill try to find it today....
and where s the thermostat? i need to check it as well
P.S. driver's side is on the right over here
so everytime anyone mention it u gotta have a look where the person is from
Old 02-25-2004, 11:59 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Unhappy possible point of interest?
Hmm...well it seems as though we all are stuck in a pickle. Its kind of disappointing that this esteemed board cant think of a solution between us. My stuttering has become so bad that its hard to gain highway speed on the on ramps! The jerky idle and sputtering under power is especially noticeable on my car b/c of the flowmaster muffler, where the car occasionally hiccups and pops during the sputtering. One interesting thing a friend of mine noticed while we were standing outside of my car while it was sputtering, was that every time that it did so, there was what sounded like an exhaust valve tapping? Sure enough, every time there was a pop or sputter, there was a tap quickly before it. Could someone look into or suggest how this might be related or tied into other suggestions? The car is almost too bad to drive now, having no power at all, and not feeling dependable.
This thing is getting depressing. My belts squeal all the time, the windshield is cracked in half, the windows dont come down smoothly, the antenna is broken, the car stutters, the window switch no longer has auto up/down, the speakers are blown, and the list goes on and on...but I will continue to drive this money pit if I can get the sputtering solved...so wont someone be my salvation!!
Thank You all, lets try and nail this problem!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 02-26-2004, 12:07 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Im not going back to look
but has anyone mentioned or changed their crank trigger
sensor yet ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 02-26-2004, 01:25 AM
nextcubepro
Re: possible point of interest?
Perhaps sell yours as an as-is parts car on ebay. For a 1992, that should pull in about $1,000. Then, look long and hard for a good SVX, that won't be a money pit. Even though you may love your little money pit, it may be time to set it free to help other SVXs with their bad parts.
Old 02-26-2004, 07:11 AM
mranderson mranderson is offline
The One
Send a message via AIM to mranderson
Re: Im not going back to look
sensor yet ?
um... never heard of it.
if you think it might help ill try. The sputtering has to end.
Old 02-26-2004, 01:17 PM
Re: Re: Im not going back to look
Crankshaft sensor retails for about $208
part # 22053AA020
thats for a 92-94 model........
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 02-26-2004, 01:27 PM
The One
Re: Re: Re: Im not going back to look
part # 22053AA020
ok maybe ill try that later when im not in college.
Old 02-26-2004, 01:58 PM
gamblergw
idle screw
Originally posted by 6evil9
oh ok i just thought u guys have problems when car is cold...
anyways have u checked all ur vacuum hoses? are they flexible and look new? i ve changed 1 so far, to regulator, things became bit better
got few other which went bad
im just trying to find what we all have in common, coz i doubt it ll be fuel pump as they dont break that often and problem is common.
anyways i did the other thing today: there is a screw which controls the idle opening of throttle batterflies. unscrewed that abit and opened the batterflies abit...seems like things became abit better
still tasting... where is that idle scree?
rmps are same, but when it drops rpms on idle, it does not shake that bad now, just abit
