Old 10-28-2003, 12:58 PM
mikecg's Avatar
mikecg mikecg is offline
Brake light
Brake light comes on sometimes. Anyone know what it means??
Old 10-28-2003, 01:19 PM
Mr. Pockets's Avatar
Moderator
Which brake light? Do you mean the one which warns you that the parking brake comes on? Most likely, I would think it would be a fault in the switch that tells the car you have released the parking brake.
If it's the 'stop lamp' light, then you have a brake light out. Unfortunately, it seems that if both brake lights on one side burn out, that warning light won't tell you.
If it's the 'ABS' light, then you have a problem with your ABS system.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-28-2003, 01:53 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: Brake light
You are probably a little low on brake fluid. As your pads wear, more fluid sits in each cylinder rather than the master cylinder.
Check your fluid level.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 10-28-2003, 04:17 PM
Green1995SVX
Re: Re: Brake light
Doug
This generally happens as temps get lower. Add a few drops of brake fluid.
Mike
Old 10-28-2003, 06:22 PM
mikecg's Avatar
Think I know
1. no ABS
2. Dont think its a burnt light because its intermitant
3. Had the car on the lift to look at the possiblity of future upgrades (ie AWD) and noticed the pads are coming do. So it's probubly needing fluid like you guys said. The cars only got 29,500 miles so it probubly has the origional pads. Im pretty sure it still has the origional rubber. Im replacing those soon to (Motegi rims & Kumho tires)
Old 10-28-2003, 06:23 PM
mikecg's Avatar
oh
Oh ya and thanks for your help.
